I am not convinced that red badges denote "turbo". I know its all over the net but I am sure I know of someone with a red badged N/A R33 who told me what it stood for but that was quite a few years ago.
I'm unsure about 34's but my first skyline was a r33 gts25 type-s which was the best of the NA r33's (slightly more power, standard viscous LSD (option on lower models)) unsure what else was different, but it had the red GT badges to differentiate it from the non type-s. I worked with a guy who after being in my car several times went out and got himself a blue badged number and it was a totally different car....haha...he was gutted..... I have fond memories of that car, it wasn't slow and was the most reliable skyline i have owned by a long long way
Hey, my GT badges are red and white on my R34 N/A. Mines a GT-V model which is essentially a GTT with a non-tubo engine. So right now I could do an engine swap to a turbo, and it would bolt straight on. It would be a lot of effort to replace the engine with a another one, then to have to change that back to the non turbo one. Though having a turbo timer does seem a bit weird. Camber wouldn't mean anything i don't think, camber is just the angle of the wheels.
I'm the first owner in Aus for my car, so nothing has been changed. I can take a picture of the badges if you'd like?
Also I do believe yours may be a GT-V as well, but can't be 100% sure. What year model is it?
Link to GT-V: http://www.sau.com.au/forums/topic/214496-r34-gt-v/
Also if you can, post a picture of your interior, speedo etc, I should be able to tell from that if it's a GT-V.
  • Like 1
If you want to see What's involved in going from DE to DET, check my build thread
In saying that, I already had the turbo chassis/driveline so it was significantly cheaper, as suggested, sell up and buy a turbo model
here's a post i wrote up for a guy who asked a similar question, but the idea is the same
http://www.sau.com.au/forums/topic/459003-25-gt-or-25gtt-help-please/?p=7587864
My r34 is the GT-V (same brakes as the GTT,brakes,LSD ECT) so i thought if i changed the pistons and rods to 8:1 and got a new ecu + turbo manifold ect it might be easier and cheaper ? Im not sure though Cheers Jordy 32
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
