I am not convinced that red badges denote "turbo". I know its all over the net but I am sure I know of someone with a red badged N/A R33 who told me what it stood for but that was quite a few years ago.
I'm unsure about 34's but my first skyline was a r33 gts25 type-s which was the best of the NA r33's (slightly more power, standard viscous LSD (option on lower models)) unsure what else was different, but it had the red GT badges to differentiate it from the non type-s. I worked with a guy who after being in my car several times went out and got himself a blue badged number and it was a totally different car....haha...he was gutted..... I have fond memories of that car, it wasn't slow and was the most reliable skyline i have owned by a long long way
Hey, my GT badges are red and white on my R34 N/A. Mines a GT-V model which is essentially a GTT with a non-tubo engine. So right now I could do an engine swap to a turbo, and it would bolt straight on. It would be a lot of effort to replace the engine with a another one, then to have to change that back to the non turbo one. Though having a turbo timer does seem a bit weird. Camber wouldn't mean anything i don't think, camber is just the angle of the wheels.
I'm the first owner in Aus for my car, so nothing has been changed. I can take a picture of the badges if you'd like?
Also I do believe yours may be a GT-V as well, but can't be 100% sure. What year model is it?
Link to GT-V: http://www.sau.com.au/forums/topic/214496-r34-gt-v/
Also if you can, post a picture of your interior, speedo etc, I should be able to tell from that if it's a GT-V.
  • Like 1
If you want to see What's involved in going from DE to DET, check my build thread
In saying that, I already had the turbo chassis/driveline so it was significantly cheaper, as suggested, sell up and buy a turbo model
here's a post i wrote up for a guy who asked a similar question, but the idea is the same
http://www.sau.com.au/forums/topic/459003-25-gt-or-25gtt-help-please/?p=7587864
My r34 is the GT-V (same brakes as the GTT,brakes,LSD ECT) so i thought if i changed the pistons and rods to 8:1 and got a new ecu + turbo manifold ect it might be easier and cheaper ? Im not sure though Cheers Jordy 32
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
