A few Japanese mobs did the two small inlet ports per pot with a butterfly valve to close off one at lower revs/loads . Toyotas was TVIS in early 4AGEs but they like Nissan with early RB20s went away from that idea .
With production engines inc turbo ones the manufacturer does everything possible to maximise the part throttle torque because again that's the state all roads car engines are in most of the time . It goes beyond port velocities to things like combustion efficiencies , in the turbo Neo 25s case Nissan kept the same static compression ratio using a smaller capacity chamber and a lower middle section on the piston crowns . Burning efficiency goes up meaning less fuel for the same heat and the ability to create better heat and therefore higher cylinder pressures at lower revs than an R33 spec R25 can . They obviously found ways to reduce detonation around the torque peak without retarding the ignition timing to the same degree . The extra torque at lower revs would be why they used better R26 rods to withstand greater compressive loads .
Because the engine was making better torque at lower revs they could afford to use a slightly larger turbine housing , which they had from the VG30 single BB turbo anyway , to slightly reduce exhaust restriction which again improves burning efficiency from less reversion pollution .
There comes a time when the turbo needs to boost to make wider throttle torque for greater acceleration or pulling power ie hill climbing . Once you fit larger turbos the boost threshold rises revs wise and you get a gap between engine alone torque and boosted state torque . To get that back you have to find efficiencies the manufacturer couldn't or wouldn't use or increase the engines capacity . Really the only things that generally work are less timing retard from reduced restrictions (eg exhaust) , higher octane rated fuels (eg 98 ULP and or Ethanol) , higher static compression ratios (provided you can beat detonation) , or the capacity increase .
I don't think the gains are there from porting an R33 spec RB25 head . I think everything you do to them is aimed at increasing the engines state of tune and that means extra flow potential at higher revs . I think the way to go with a street R25DET is to do as Nissan did with their Neo version , it costs lots of money to develop production engines at manufacturer level and if they could have got the desired result with simpler changes they would have .
I also like someone's standard parts where possible because someone else did the hard expensive yards to develop them . This includes heads and pistons . I said before if I ever went inside my 33 25T it would get Neo rods pistons and head . The inlet manifold system stays optional but I would stand to gain the greater part of what Nissan did with a bolt in package that keeps the original engine number . In basic terms all you have to cater to is the different CAS wiring if you use the original inlet manifold etc .
In the end most Japanese performance engines from the 1980s-90s didn't make it too far past 2000 . The RBs the SRs the CAs etc were all finished and I think even the 4G63T only went to 2006 , that had a new MiVec head for the 9s only which would have been expensive .
Basically the latest/last revision of most engines is the cheapest and best way to go . You would not use a Red Top NICS RB20DET if you could get your hands on the later R32 GTST version . I doubt there's anything positive a GTS25T engine can do that a GTt one can't do better . Given a choice its always going to be a better basis standard or modified .
A .
  • Like 1
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
