Nulon Nationals Round 4 - 26th September - Final Drag Battle!
Ok guys, round 4 is almost upon us and it's a very tight race! We have retained most of the team from last year and are fortunate enough that we have a lineup full of Cootamundra veterans!
This is a really awesome event and we would like to extend a massive thankyou to Nulon for allowing us to take part!
Please get behind the team here and head down for support!
Current standings are as follows:
team-results-after-3-rounds_zpsktymc7uk.
More info can be found on the Nulon Nats Facebook page, please head over and LIKE! :)
Team listing is as follows. Of course being Nissans and with GTRs this lineup is subject to change!
Ninos 180SX (Equal first place last year)
Dom R34 GTR (Equal first place last year)
Tyrie S13
Mark S13 (Current Motive DVD Drag Battle Champ!)
Adam R34 GTR
Andrew R32 GTR (Reserve)
If the results are anything like last year, we are in for a very close series, the top 20 cars that have already entered have run 10s or better and i have heard rumors of a few 9 second evos driving to the event to stir things up.
  • 1 month later...
We won round 4 and the series without bonus points. RTDC won the series by about 20points with bonus points.
I think the drag team came 1st, 2nd, 5th, 7th and 8th (I was 8th and pretty disappointed not to run a 10)
well congrats to RTDC on taking out the championship then, I take it the bonus points relate to their choice to keep the same cars round to round which seems fair to me
Also I think SAU should be proud of coming home second, we had great involvement across a lot of club members, and I bet everyone enjoyed the events. And considering there are 10 clubs competing across 4 rounds I reckon it is a pretty serious competition so 2nd is great outcome.
And finally, well done to Nulon for creating and sticking with this concept....everyone go out and buy their oils!!!
  • Like 3
To have 5 cars in the top 10 is a massive accomplishment
guess sau will have to run a round next year and cheat by giving time penalties to cars that didnt get any.. ya know cause in the spirit of keeping things even
When did this happen?
Agreed, awesome work buy the all the guys who competed this year. There were a lot of people gunning for SAU and to only miss out by 20 points is something to be proud of
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
