Hi there!
Recently my car just got a preoblem I cant figure out of.
I am currently running Apexi PFC D-Jetro (MAP sensors).
The issue is that when I drive normaly, on low RPM the car is hesitating and "jumpy", and when I release the throttle it will backfire all the time until I apply throttle again.
While this happens I can see on my hand commander that the ignition timing is going up and down at the same time as the backfires occurs.
Also the idle is rough, going up and down from about 900 rpm to about 1.3k rpm.
However, I can park the car and go for shopping or even fuel my car, and when I start it and drive, it behaves perfect with no backfires or no hesitation.
Also, about 70% of the time, if I rev the car and empty the gears to the revlimiter the issue will go away for a while, and then it comes back.
I have tried to wiggle cables, checking hoseclamps, replaced sparkplugs, replaced the CAS. But this issue is really something I cant figure out.
Anyone here with some tips on troubleshooting this issue?
Edit:
Here is two small videos that I made. taken only minutes after eachother, after some shopping.
Bad idle:
https://www.youtube.com/watch?v=T2MG9Pf_jeU
Good idle:
https://www.youtube.com/watch?v=h7mUYNZii0U
Best regards,
Thomas
Edited by Acrula
Hi there all,
Thank you for taking time to reply on my thread.
I have tried allot of things now back and forth and it seems that I have managed to get the backfiring gone when releasing throttle.
There was a loose nut on one of the throttlebodies and it seems that it had screwed itself out abit, making it not sealing proper when throttle is shut.
I did really hope that this also was causing the bad idle, but the idle is still the same, rough sometimes, sometimes its not. Today i replaced the AAC valve, and cleaned it really good before install.
I also replaced the PCV valve, since it is so easy, I just had to try it.
Then I also replaced the TPS, since i noticed on my commander that the black dot for "idle" didnt tick when releasing the throttle, after TPS replacement there is now a black dot on "idle". But yet, the idle is still rough.
So I guess I have to try some more stuff tomorrow then, and I will update if things go better:)
Best regards,
Thomas
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
