so recently my r32 was dying due to the alternator not charging the battery, i took it out and replaced it with an rb25 alternator as i found they bolt right in and can be used on the rb20, went to reconnect my battery and got a couple sparks while doing so even though i made sure no electrics were on, however connected it up and car started up first go no worries. The problem is my electrics now dont work, no interior lights, no radio, no dash lights, no windows/mirrors. the parkers and headlights/tail lights still work and all mechanical components work normally, any ideas what this could be?
https://www.sau.com.au/forums/topic/459155-r32-electrics-gone/
Not sure if r32 would have big wiring loom running inside the drivers side front guard but i had similar dramas with r33 electrics, coz of car being too low, tyres rubbed through the big wiring loom and all the wires were melted together.
i think they do however i'm fairly sure mine has been tucked and my car isnt crazy low either, i've never had any issues with my electrics but as soon as i turned the car on with the new alternator everything stopped working
so i'm pretty sure i found the problem, main fuse completely gone lol, the one that says 75A in the engine bay, does anyone know how much current an rb25 alternator flows? im assuming the rb20 ones flow 70A and rb25 flows more than 75A
The issue is when you first connected it up with the battery. That's when it blew. The car wasn't even running.
I don't believe the replacement alternators ampage is the issue as there is not a significant difference.
Well it can draw up to 90A.
No, it PRODUCES (up to) 90A, then feeds it back into the battery. That amperage does not go through the fusible links, there is no risk that the alternator can blow the links or other fuses.
FWIW, in the "olden days", my 180B SSS ran a quite small alternator - about 45A. Because it used 100W Cibie driving lamps in "rally car" trim, the alternator was upgraded to about 80A, with no other modification to the electrics, and no problems with fuses blowing. Such an upgrade was quite commoin in rally cars of the day (70s, 80s).
  • Like 1
the only problem was the power cable that looked like an earth, on the rb20 its too small to fit on the rb25 nut so you have to cut it and put a bigger one on, other than that its perfect fitment so i'd recommend it to anyone who's electrics seem weak
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
