so recently my r32 was dying due to the alternator not charging the battery, i took it out and replaced it with an rb25 alternator as i found they bolt right in and can be used on the rb20, went to reconnect my battery and got a couple sparks while doing so even though i made sure no electrics were on, however connected it up and car started up first go no worries. The problem is my electrics now dont work, no interior lights, no radio, no dash lights, no windows/mirrors. the parkers and headlights/tail lights still work and all mechanical components work normally, any ideas what this could be?
https://www.sau.com.au/forums/topic/459155-r32-electrics-gone/
Not sure if r32 would have big wiring loom running inside the drivers side front guard but i had similar dramas with r33 electrics, coz of car being too low, tyres rubbed through the big wiring loom and all the wires were melted together.
i think they do however i'm fairly sure mine has been tucked and my car isnt crazy low either, i've never had any issues with my electrics but as soon as i turned the car on with the new alternator everything stopped working
so i'm pretty sure i found the problem, main fuse completely gone lol, the one that says 75A in the engine bay, does anyone know how much current an rb25 alternator flows? im assuming the rb20 ones flow 70A and rb25 flows more than 75A
The issue is when you first connected it up with the battery. That's when it blew. The car wasn't even running.
I don't believe the replacement alternators ampage is the issue as there is not a significant difference.
Well it can draw up to 90A.
No, it PRODUCES (up to) 90A, then feeds it back into the battery. That amperage does not go through the fusible links, there is no risk that the alternator can blow the links or other fuses.
FWIW, in the "olden days", my 180B SSS ran a quite small alternator - about 45A. Because it used 100W Cibie driving lamps in "rally car" trim, the alternator was upgraded to about 80A, with no other modification to the electrics, and no problems with fuses blowing. Such an upgrade was quite commoin in rally cars of the day (70s, 80s).
  • Like 1
the only problem was the power cable that looked like an earth, on the rb20 its too small to fit on the rb25 nut so you have to cut it and put a bigger one on, other than that its perfect fitment so i'd recommend it to anyone who's electrics seem weak
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
