Having been in a v cam 2.6, it would be about equal from 3500 ish compared to a 2.8. From the basement you can't hide cubes/stroke.
* very rough figures though.
There will be a comparison between the 2.6/v cam vs 2.8 using exactly the same turbo soon enough.
  • Like 2
They are still talking about Stroker Vs 26, they just do not agree. Hit him with your hand bag Joey :domokun:
I think Joey has been in enough different Rs to make an educated statement about strokers Vs 26, just do not get Piggaz started on strokers Vs 26 :woot: ​. Have a look at Piggaz car, stroker and a worked head.
From what I can work out , you like them or you don't , you like to rev them hard or you would rather have your car working earlier. It seems you can do this with both with the right mods, but I would imagine that with extra CCs a stroker has to be a little better.
Cutty, ask a few of these blokes if you can get a run in their cars. From my limited experience Dynos look impressive but until you drive them you do not get the full impact of how the car drives on the "street".
Cheers Pete,
Considering my first reply was a legitimate one, I can't help if people want to reply in that manner.
Anyway, I actually hate this expression but it does ring truth
"There's no replacement for displacement", seems these days more and more people are going stroker kits
  • Like 1
BA37A3EC-116D-401E-94E5-3ECBA3AD1AFB_zps
For a bloke that has never driven a stroker, you know a lot about the advantages of them, how they drive, blah blah.
Farken 2.6L junk. Bin it.
It has nothing to do with peak power. How can having more low to mid range twist be considered a bad thing?
  • Like 2
A 28 is to a 30 what a 26 is to a 28
.... about...... Not rocket science is it. I have driven enough 30s in my time.
My LS2 had twist from idle and a found that as boring as shit, unless burnouts of course.
Mid range twist is for lazy c%&$ who want to brag about how fat their dyno sheets are so they don't have to change gears...... Suggestion...... Get an auto.
You guys are funny.
Can't wait for my TO4z setup to be on the road so I can thrash the f#@k out of it.
Edited by XGTRX
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
