Post any traffic light contenders urve burnt or been burnt by !!!
The first drag i had was against a 99' WRX which had an exhaust,f/m and could see power fc handset on his dash.
but anyway he got on me on off the line but once the HKS turb started boostin CYA !!! ive got a 32' with HKS 2535 turbo,GTR f/m,full exhaust system high flow cat,Microtech managment etc :thumbsup:
https://www.sau.com.au/forums/topic/45917-cars-urve-burnt/
Yeah that counts.
I was gettin it on in the back seat and got carpet burn.
Does that count?
definately
picked up a beef vindaloo once in my car from a take away place, dropped a tiny bit of the sauce on the floormat, now i dunno if cars actually react to spices but i would say that my car got burnt in that instance
https://www.sau.com.au/forums/topic/45917-cars-urve-burnt/#findComment-933575
fully sik bro!!11 CHEck ThiS RigHt I was HangiNg Wif' Me bRos AnD ThIs FuLLy SIck Lanos WOz At ThE LighTs AnD He HAd the woRks Bro, HeCtiC AnD ALL MAn You SHouLd HaVE SeeN ThE BODY KIT!!!11!eleven!! SO Then We WAs At THE LIGhts And I Smoked ThAT FOOl!!!11! My CIviC BURNT THAT SUCKER!!!1!!!1 ROFLMAOWTF
https://www.sau.com.au/forums/topic/45917-cars-urve-burnt/#findComment-933677
On the way home the right side of my face usually gets burnt.
Its all good
I eat tea; i'm usually so hungry my tounge gets burnt.
Its all good
The day will come when my mattress is burnt by the electric blanket.
Its all good
Your freezing your arse off first thing in the morning, jump in the shower and get burnt.
Its all good
The left side of my face doesn't get burnt driving in the morning.
Its all good
Moral of the story; its all good until you get burnt.
https://www.sau.com.au/forums/topic/45917-cars-urve-burnt/#findComment-934658
Guest
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
