Hi all,
How are people locking off their ignition advance to set base timing? I've got an inductive pickup timing light with the pickup clipped around the white wire loop at the start of the coil harness (it's at the back near the firewall), but the ECU is constantly varying the timing and it's very difficult to read. How have other people locked it at 15 degrees?
I have tried Conzult's "idle setting" but that doesn't tell me what the timing is set to, and it doesn't seem to be constant. It just seems to adjust the idle speed.
Cheers
DaveB
https://www.sau.com.au/forums/topic/459187-setting-timing-on-25det-neo/
And check the sticker on you bonnet to see what it should be set at. I believe auto and manual base timing is different. And yes unplug TPS and use an old spark plug lead between cyl 1 coilpack and plug.
Well I tried timing from various points and comparing them to the #1 spark plug using an HT-driven timing light, and I can now say for sure that timing off the loop wires shows about 15 degrees more advance than using the #1 spark plug method. I took some pictures if people are interested but I hope this is enough.
Some weirdness I noticed, has anybody ever seen this? With TPS unplugged (thanks owen1r) I loosened all 3 bolts on the CAS sensor, and then rotated until I observed the same timing with the light that the ECU was commanding (in this case 12 degrees). That was fine. But then I would notice that as soon as I tightened just one of the bolts to even finger tight, the timing would change back to like 5 degrees?! The CAS was definitely not rotating, and it would have to rotate a significant amount to make that much difference to the timing. Does anybody know what could be going on there? This is my second CAS too since I replaced it a while ago.
thanks
David
Lots of timing lights (generally the less expensive ones) read double the actual timing from the loop at the back, so if you are seeing 30o you can probably read that as 15o
Interesting to know thanks Duncan. Do you have any suggestion for why it might be changing when I tighten the CAS? I'm a bit worried that the CAS is reading UNDER, and therefore I might have more timing than there should be.
Edited by DaveB
I don't think it's that simple and I wouldn't like to just guess.
If the gun is picking up the leading edge of the current in the loop wire, the amount of dwell is added to the timing reading. It might look like double, bit that's basically just a fluke. It should really pick up on the falling edge of the loop wire to be accurate.
I would still not trust it, a plug lead between coil and plug is best option.
  • Like 1
I compared both and I couldn't find any correlation.
With the inductive pickup timing light, off this wire:
...I measured about 22 degrees:
But with an older style timing light, that connects directly to the spark plug (it has a long spring which fitted into the coilpack), it read about 5 degrees!
  • Like 1
Do some maths. I'm sure it would be able to be calculated back to the dwell of the coil.
I seriously can't be bothered looking I to it further!
It's enough to know to not trust/use the loop, especially without checking it to a lead.
Sure. What I meant to say was, it doesn't look easy like 2 x the spark-measured value or something similar.
  • Like 1
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
