Hi Guys
Recently just got my car back, 95 r33 gtr vspec. was getting eflex and tune after couple new parts.
Driving home I was getting a bit of a sway or wobble in the rear, felt like the rear. normally I like a little bit of wobble but not on the car haha.
So took it easy it was only when I went over a rise or bit of a bump in a dip. Ive had shot suspension before and definitely didn't feel like that.
So checked all wheel nuts when I got home, all good and tight. went down to pump up tires as they were a little low, 15psi then what I would usually have them. went for a drive felt good. gave it a little and the wobble was back. Pulled over and had a quick look under. all nuts and bolts where there and seemed good.
Got home and jacked it up, gave it a once over. Found that I could move the passenger side wheel to the left and right, well left and back again, about 2mm or so. Driver side is all tight no movement. The movement seems to be coming form the join at the steering rack. The tie rod doesn't have movement anywhere.
My questions are, am I right in assuming that there should be no movement at all, and this is what could be giving me the "wobble".
if so, are there any bushes I can replace rather then the rack itself, as the exploded diagram from Nissan doesn't have anything apart from rack, and the tie rods, covers and what not. or an over haul kit or something of the like.
Has anyone else had an issue like this and should I just put a hicas lock bar in as most likely cheaper. Also is it just a simple job as the 33 is elec rather then the hydraulic one on the 32s.
thanks for any help you guys can offer. any pics also to reference would be appreciated. I have attached the view Nissan sent me.
cheers guys
image2015-08-24-121100.pdf
https://www.sau.com.au/forums/topic/459201-a-wobble-in-the-rear-end/
it didn't seem like it had any movement, but I didn't pull it all the way off to check. had to get more tools from the ute and wasn't overly keen that arvo. thought id ask a question first before ripping it apart. but I do plan on pulling the tie rod off so I can check the ball joint for movement and then the actual shaft into the rack.
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
