Hi Guys
Recently just got my car back, 95 r33 gtr vspec. was getting eflex and tune after couple new parts.
Driving home I was getting a bit of a sway or wobble in the rear, felt like the rear. normally I like a little bit of wobble but not on the car haha.
So took it easy it was only when I went over a rise or bit of a bump in a dip. Ive had shot suspension before and definitely didn't feel like that.
So checked all wheel nuts when I got home, all good and tight. went down to pump up tires as they were a little low, 15psi then what I would usually have them. went for a drive felt good. gave it a little and the wobble was back. Pulled over and had a quick look under. all nuts and bolts where there and seemed good.
Got home and jacked it up, gave it a once over. Found that I could move the passenger side wheel to the left and right, well left and back again, about 2mm or so. Driver side is all tight no movement. The movement seems to be coming form the join at the steering rack. The tie rod doesn't have movement anywhere.
My questions are, am I right in assuming that there should be no movement at all, and this is what could be giving me the "wobble".
if so, are there any bushes I can replace rather then the rack itself, as the exploded diagram from Nissan doesn't have anything apart from rack, and the tie rods, covers and what not. or an over haul kit or something of the like.
Has anyone else had an issue like this and should I just put a hicas lock bar in as most likely cheaper. Also is it just a simple job as the 33 is elec rather then the hydraulic one on the 32s.
thanks for any help you guys can offer. any pics also to reference would be appreciated. I have attached the view Nissan sent me.
cheers guys
image2015-08-24-121100.pdf
https://www.sau.com.au/forums/topic/459201-a-wobble-in-the-rear-end/
it didn't seem like it had any movement, but I didn't pull it all the way off to check. had to get more tools from the ute and wasn't overly keen that arvo. thought id ask a question first before ripping it apart. but I do plan on pulling the tie rod off so I can check the ball joint for movement and then the actual shaft into the rack.
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
