Okay so i have a 1992 R32 GTS4, it has a chronic scraping sound coming from the right wheel area when full lock left, we have had the wheel off, looked for scrapes, had the brake caliper off and apart to check for road debris caught in the caliper, had the rotor off to make sure nothing was between the rotor and the back plate, we took the ABS sensor out to make sure it wasn't scoring on the gears, no visible signs of scratching which is what i would expect from the horrific sound. Anyway after roughly 3 hours with a mechanic he said that he wants to replace the entire wheel hub, to eliminate that completely which is fine as second hand they are only 50-100 dollars.
Ok so now for the real question, does anyone know if the R32 GTR Wheel hub and the R32 GTS4 wheel hub (front) are compatible / bolt straight in. To my understanding mechanically they are very similar (except for the obvious not having a cool engine etc)
Any assistance would be greatly appreciated.
Thanks in advance.
https://www.sau.com.au/forums/topic/459204-r32-skyline-buffs-i-need-your-help/
Before you go throwing money at the "problem", tell us:
What size wheels are you running (diameter, width, offset). Tyres (width, profile)?
How much camber? caster?
In my experience, the only problem I have with scraping is high speed cornering left on uneven surfaces. And the culprit is most likely the wheel rubbing on the arch liner when the suspension goes into bump / compression (lh arch liner has gone bye-byes, so I don't have the problem on right turns).
FYI - the setup on my 89 GTS4 is 17x 8" rims (not sure of offset), about 1 deg -ve camber, unknown (probably stock) castor.
One other thing you might look for is the wear marker on the brake pads rubbing on the rotor (although that would be a chronic "all the time" scraping).
And in my experience, GT-R / GTS4 suspension components are generally interchangeable.
  • Like 1
Hi thanks for your reply, The wheel it self isn't scrubbing on anything. they are 18" wheels not sure on width or offset but i've owned the vehicle for around 18 months and only over the last month has it started doing it. The hub bolt was a bit lose but after tightening that the squeel went from consistent to only happening on the hard lock left leading my mechanic to thing with the wheel being a wee bit wobbly something might have bent so replacing the entire hub was the best way to go about it. as for turning at speed you can hear the scrape even if you are travelling at close to 0 KMPH just slowly rolling forward in hard lock left its just really slow and played out scrape but its metal on metal brakes were done about 6 months ago i believe
maybe replacing / machining the rotors wouldn't be a bad idea anyway really
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
