Okay so i have a 1992 R32 GTS4, it has a chronic scraping sound coming from the right wheel area when full lock left, we have had the wheel off, looked for scrapes, had the brake caliper off and apart to check for road debris caught in the caliper, had the rotor off to make sure nothing was between the rotor and the back plate, we took the ABS sensor out to make sure it wasn't scoring on the gears, no visible signs of scratching which is what i would expect from the horrific sound. Anyway after roughly 3 hours with a mechanic he said that he wants to replace the entire wheel hub, to eliminate that completely which is fine as second hand they are only 50-100 dollars.
Ok so now for the real question, does anyone know if the R32 GTR Wheel hub and the R32 GTS4 wheel hub (front) are compatible / bolt straight in. To my understanding mechanically they are very similar (except for the obvious not having a cool engine etc)
Any assistance would be greatly appreciated.
Thanks in advance.
https://www.sau.com.au/forums/topic/459204-r32-skyline-buffs-i-need-your-help/
Before you go throwing money at the "problem", tell us:
What size wheels are you running (diameter, width, offset). Tyres (width, profile)?
How much camber? caster?
In my experience, the only problem I have with scraping is high speed cornering left on uneven surfaces. And the culprit is most likely the wheel rubbing on the arch liner when the suspension goes into bump / compression (lh arch liner has gone bye-byes, so I don't have the problem on right turns).
FYI - the setup on my 89 GTS4 is 17x 8" rims (not sure of offset), about 1 deg -ve camber, unknown (probably stock) castor.
One other thing you might look for is the wear marker on the brake pads rubbing on the rotor (although that would be a chronic "all the time" scraping).
And in my experience, GT-R / GTS4 suspension components are generally interchangeable.
  • Like 1
Hi thanks for your reply, The wheel it self isn't scrubbing on anything. they are 18" wheels not sure on width or offset but i've owned the vehicle for around 18 months and only over the last month has it started doing it. The hub bolt was a bit lose but after tightening that the squeel went from consistent to only happening on the hard lock left leading my mechanic to thing with the wheel being a wee bit wobbly something might have bent so replacing the entire hub was the best way to go about it. as for turning at speed you can hear the scrape even if you are travelling at close to 0 KMPH just slowly rolling forward in hard lock left its just really slow and played out scrape but its metal on metal brakes were done about 6 months ago i believe
maybe replacing / machining the rotors wouldn't be a bad idea anyway really
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
