Hi All,
I purchased my old turbo kit back from Alex. Was going to buy another NM35 but my plans have changed.
This kit will run on standard injectors or crank it up to about 280AWKW's on 98 or 315AWKW's on E85 with all additional mods(Of which I can do).
So up for sale is the kit below if you want to install it yourself:
  • Rebuilt and balanced Garret BB 30/71r internals into our original housings
  • Lower suction pipe
  • Custom made Turbosmart actuator setup
  • Modified front pipe to the intercooler
  • New oil feed line with an inline filter
$1,850
If you want me to install it i'll do the whole thing less the upper intake pipe(which I can get made at your cost approx $300) for $2350.
If you think thats to expensive to do a standard bush SS1 or SS2 turbo high flow unit its approx $2,200.
P.S. If I do the job I will have to get the top pipe made up so I will need a couple more days.
any questions feel free to buzz me on 0406754304 or PM me.
Cheers
Craig
https://www.sau.com.au/forums/topic/459208-vq25det-3071r-turbo-kit/
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
