Hi I'm new to this forum had my car for about 2and a half years so have got to know my car well just a quick question I usually service my car with motul 300v chrono 10W 40 every 5000kms but while I was down south I needed to top up oil and the best I could get was penrite hpr 15w 40 semi synthetic would've used no more than about 800 ml and I'm just really worried if I done any damage to it drove about 300km since top up am I better off not driving it till I do an oil change as it seems a bit different when driving. Cars a r33Gtr with mild mods sorry if question has been asked before couldn't find a specific answer relating to my concerns. Any advice will be greatly appreciated
https://www.sau.com.au/forums/topic/459215-oil-issue/
Ryco are fine, you need a new mechanic mate. The only thing the greddy filter gives you is a big hit to the wallet that you don't need.
I bet if you opened them up internally they would be very similar if not the same type of filter material and design.
The comparison has been done between an OEM and Ryco filter and the difference between the two was not much.
https://www.sau.com.au/forums/topic/459215-oil-issue/#findComment-7594249
Mate I think you need to apply your own thoughts instead of taking what your mechanic says as gospel.
At any oil change, do you really think every last cc of oil comes out that sump plug?
Of course not, there's always going to be dilution of your new oil with old oil remaining in galleries and various pockets.
Now if you noticed some dramatic change in your car's road performance after you topped up with 800cc of different viscosity oil, I'd be more concerned how come it needed topping up at all.
  • Like 1
https://www.sau.com.au/forums/topic/459215-oil-issue/#findComment-7594269
I know not every drop comes out at oil changes I'm definitely looking for a new workshop, I thought it could be losing oil somewhere cause usually when I service I don't require any top up. As for dramatically losing performance just was told oil was to thick to flow properly but I now think that's not the case and I doubt it needs a new dyno tune after a few months. As for the filter I done some research and it's definitely not worth the extra cash so going to be using ryco filters from now on.
https://www.sau.com.au/forums/topic/459215-oil-issue/#findComment-7594301
    • That’s a beautiful setup Tao, Have u done any development with the new Turbosmart 40mm electronic straight gate, especially in this G30 configuration?
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
