My RB25 has developed a ticking sound which appears when the engine is warm and only at idle. Anything above idle and it seems to disappear.
It is *not* the injectors pulsing. In fact it can barely be heard when your head is over the engine.
You can hear it best when listening either below the engine or at the back of the front wheel wells.
I tried using a wooden dowel/long screwdriver stethoscope but couldn't isolate the origin of the sound.
I recorded a short audio clip from below the car which demonstrates the sound:
I first thought sticky lifters or a leaking exhaust gasket, but they would presumably appear worse when cold. This sound only appears when the engine is up to temp.
Ideas?
https://www.sau.com.au/forums/topic/459216-ticking-sound-on-idle-rb25/
  • 4 years later...
  • 2 years later...
G’day, I Have this exact same noise in the video, anyone end up figuring it out? Same issue as originally described and tried everything OP did aswell. Only once warmed up, runs and sounds fine while warming up. Not an exhaust leak, all new gaskets + studs, washers and nuts for manifold and turbo. Also changed oil and filter plus trying different oil viscosities, hasn’t made a difference.
Leaning towards lifters but due to it being alright on cold start has me baffled.
  • 7 months later...
VCT is working fine, it’s even difficult to locate the sound with a stethoscope. However definitely audible from under the engine as with OP’s video. Possibly worn bearings but it’s definitely not a knock. The sound can be heard while driving with the window down aswell when passing a barrier or other cars when the sound bounces back. Sounds like a little jingle bell weirdly enough. Any other ideas?
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
