Hi all...want to see if someone can help out with this...I bought this low 70k 34 a year ago..ever since its had boost issues... so today I wrote down the max boost I recieve with my boost controller turned off and using my internal wastegate..
1st gear I get 7psi !
2nd gear 8psi
3rd gear around 9psi
4th gear just under 10psi
5th full boost of 10 psi.
I use a hks evc 5..when this is on I revive a little higher boost of course..If I'm set to hi mode..15psi in 5th gear..though any Lower gears less boost..1st will only ever reach around 9psi.. 2nd 10psi.. 3rd 12psi and 4th can be 13psi and 5th full boost..I can't find any leaks..All hoses have been changed.ive changed my intake as it was custom made and way to short..changed bov incase the turbosmart that came with It was leaking..
New tune on my nistune board by toshi.
Changed spark plugs..coil packs to splitfire.. All hose clamps are tight..
Car has
nistune ecu
z32 afm
Tomei poncams 252
Full 3inch exhaust
Just jap return flow intercooler
Custom metal intake.
Walbro 255 fuel pump
splitfire coils
Large garret turbo. It came with the car and had only about 3k on it. It does have a larger intake connection then a stock skyline turbo..3 inches. So my intake that joints to it us 3inches.. A guy looked up my turbos serial number and was saying may be a gtx garret..It did seem to have double fins on each fin when the intake was installed..
Does anyone have any ideas or why my car has down low boost issues ?.. is there a sensor stopping this or can it be a faulty boost sensor ? Is their anything I can look at with my consult cable to check if anything is maxing out a voltage somewhere ? ...seems some days I can get 1 or 2psi more if km lucky or the car is cold..Thank you
Edited by seriesII
https://www.sau.com.au/forums/topic/459221-r34-gtt-boost-issue-driving-me-nuts/
Oh to add..when I've had it on high boost 15psi. I've seen my turbosmart boost gauge go to 13psi or 14 then it will drop to 10psi in 3rd and 2nd gear..I've had it feel like it launches with power then the boost drops down by 4psi or so and back down to 10psi.. until I hit 5th gear which will hit 15psi. Getting so annoyed with this car..and it's in perfect condition not even a oil drop out of the car
It's has a nistune board installed..not stand engine management.. and was tuned by toshi for 16psi.. so I should get a retune again ,.?.. If it keeps the issue up while tuning I guess it could start costing a bit though..
Toshi is a top notch tuner known by many and one of the best.. even he had this boost issue tuning my car..3rd gear would spike up to 15psi then drop down to 10 psi within 2 seconds.. another tune with this issue seems like it could be a waste of money if I can't find what the issue may be..was unaware the ecu would control boost except for the boost pressure sensor on the 34s.. just seeing if anyone has any ideas I have missed on to why this is going on.
Edited by seriesII
Boost controller seems perfect..well its set up perfect.. I tried a turbosmart the piece.the duel when I got the car..It did the dawn thing. Maby ill hook up the stock solenoid and see what is does ? . I have not tried to presure test..good idea ;)..can any place just do that ?..I guess I would have to take my pipes of ? ..
Gtsboy..that's okay..I had a lot of info ;) .. It is a all in one dump and down pipe..
It does seem when the car is cold..10 mins of warm up and then driving I can get around 9.3psi in 2nd and the other gears.. Once it's a lot hoter seems to not make it to that
Edited by seriesII
You say upgraded intake. Is it all metal? Does it have anywhere it can collapse?
I had a home made snorkel on the standard air box (to allow for the FMIC piping) that was collapsing under the suction created at high boost so I'd go from 18psi down to 0psi at about 5k rpm. Worse in the higher gears since more load / air being pulled in.
Looked at everything before that.. May not be the same issue but worth having a look at your intake, especially pre turbo to make sure there's no weak points
  • Like 1
A smoke test only pressurises the intake to .0001 psi, your leak may only appear at 10psi. I always use a compressor and put 20 to 30 psi in the intake, you would be surprised how many leaks I can usually find.
Do you know what pressure the actuator is supposed to hold?
  • Like 1
Thanks so much for the time to reply guys..so appreciate it... its funny as I have paper work that has just before I bought the car for a new waste gate that is set to 14psi..so wtf..yet max I get is 10psi if I use just the intrenal gate to control my boost :(...I might try this pressure test with a compressor.. Scott when you say intake..would I just remove my pod filter and pop 20psi in there ?..or I could remove the engine oil breather line on my metal intake and pop the compressor in there ? Thanks
Definitely today in first gear using the waste gate with stock solenoid connected..7psi in first.. 8 ish in 2nd and 9psi in 3rd.grr
Edited by seriesII
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
