For sale 1993 r32 gtst factory manual S1 r33 rb25det engine Forged Pistons Gtr rods Gtr valves R34 rb25det box Twin plate clutch of some kind Gt35⁄40 turbo low mount Vipec computer Stainless cooler piping and front mount 550cc injectors Spitfire coil packs 3 inch exhaust with high flow cat and a resonator (really deep note) Alloy custom front facing plenum Alloy radiator Bride seat Gtr door cards front and rear Bc coil overs Adjustable Camber arms front and rear Adjustable castor arms front Gtr front bar, lip and bonnet Yokohama AVS model 6 17" wheels wrapped in falken tyres Makes a bit over 400hp at the treads Super fun car, flys in a straight line and handles like its on rails Was my daily for a few years never let me down once. Regularly serviced with penrite full synthetic, usual no more than 3,000kms between oil changes. A⁄c works Paint and body in good condition overall, few dints and scratches Crease in the bottom of passenger door and a bit of fade on the roof. The car always gets compliments on how clean and straight it is for a 32 Car has around 290,000kms Engine has about 30,000 Only selling to fund rx7 project. 10,300 can supply rwc and 6 months rego May swap for a road cruiser motorbike plus cash my way
give me a text or a call 0434282866
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
