1997 180SX Type X, 85,000 km, sunroof.
If you want a clean, reliable Type X with all the work done look no further.
Engine & drivetrain
SR20 comp tested to 140psi 1-4
New Hardrace engine and gearbox mounts
New belts
New OEM water pump
New OEM thermostat
S14 Radiator
New rear main seal
New OEM gaskets throughout intake and exhaust.
Replaced IACV
R33 Clutch Fan
FMIC
Turbosmart boost tee at 10psi
S15 BB T28
Speedflow Teflon oil and water lines in fireproof wrap.
DEI heat-wrapped manifold
Exedy clutch
AC-delete
One-piece front and dump, HKS cannon catback
S13 5-speed box, shifts perfectly no crunching
Nismo short shifter
New battery and terminals
New fluids throughout (Royal Purple engine, Martini gearbox, Motul diff, Castrol brake fluid)
Interior
Excellent condition, no cracks in the dash
Steering wheel is excellent.
Pioneer double din headunit w/ iphone integration
Bride glovebox
Type-X Seats
Turbosmart boost gauge
Suspension
5-Stud with new bearings
New whiteline subfame bushes
S15 brakes, DBA rotors, S15 BM50 master cylinder
Hot Bits Coilovers (Made in Germany)
Whiteline swaybars front and rear with end links
Exterior
5000km old respray in Renault Graphite
Dmax roofwing
Pods and rear valence included (require fitting)
Please note CA lip has been sold separately
$12,500 ONO/Negotiable.
Points to note:
Car is located in Melbourne, VIC and will be sold without NSW registration/rwc. PPSR showing clear title and clear WOVR status available.
Fan shroud is included however with the hardrace mounts the R33 fan interferes with the shroud. Had no issues whatsoever with engine temps (monitored via Consult port).
RPF1 17x9.5+18 w/595-RSR 235/45/17 +$1k or BYO wheels.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
