Got myself a set of ID1000, mechanic tried to drill my OEM rail, ended up leaking.. so I'm back to square one. I already have a Nismo Type-A regulator so I would prefer to keep the single entry/nismo FPR and just get the cheapest 11mm fuel rail. Which one would it be ? or it doesn't even exist ( they are all dual entry) ?
I'm not looking for fancy fuel setup with AN hose or mega 2000cc or E85 setup, so i reckon a simple fuel rail design would work as long as it's not a china knock-off with poor sealing thread than these are pointless.
Is this what you are after? it mates the stock reg with an aftermarket rail.
Or just find a replacement stock rail and get the correct injector adapters... and a new mechanic. :P
  • Like 1
Agreed.
This would not have been a problem
never seen an adaptor like that, so i suppose this is what i need lol or maybe i would be better off with an external FPR.. how much this adaptor cost ?
edit: found this.. radiumauto. seems like they are the only one making an adaptor for aftermarket rail to bolt-on stock/Nismo FPR https://www.radiumauto.com/FPR-Adapter-for-Nissan-P602.aspx
Edited by cobrAA
If you won't be adjusting fuel pressure then you'd be fine with the OEM FPR.
Also the stock rail and injector adapters is probably the best solution if that is the case. The HKS rail and adjustable FPR is just going to be bling you won't even need.
Are you looking to adjust fuel pressure?
I won't, but I know the tuner had to adjust pressure with my gt2860's old setup.
If it's needed, I will get the big package, but i want to avoid bling factor. I'm aiming good HP, but I don't really plan on trashing the car so I thought the Nismo would be fine, but then I had second thought and i need to decide on my fuel setup ASAP since car should be done within a week
I don't understand why your injectors don't fit the stock rail, there should be no need to drill the rail out to match the injectors, in fact you would be mad to as it would never seal.
Can you take a picture of what you bought? I am sure I can point you in the right direction...
  • Like 1
Shouldn't have to adjust pressure unless injectors were not up to the task and he was trying to push more fuel through.
They were 700cc sard. maybe they were, in fact, not up to task.
It was a BNR32 rail. Mechanic said it didn't fit. over-bored as he said it was leaking after the mod. So now, we're back to square one.
Either I buy my friend's BNR34 rail and bring it to a machine shop ( I say ppl who couldn't make the ID1000 11mm fit and had to drill and some say that with lots of lube/pressure it fitted..)
or I buy HKS rail + adaptor + FPR + hose
The gtr rail won't accept 11mm, you need smaller adapters than that. The many hundreds I have sold have all fitted fine. What makes you think an aftermarket rail will help?
Did you tell ID they were for a GTR? If so send them back.
you have the wrong adapters.... in 2mins you can fix it by getting the same adapters as ive listed below... these are a bit dear @7ea though so shop around.
http://www.asnuperformance.com.au/gallery/Injector%2BExtensions/injector-extension-adapter-to-10mm-denso/123094?view=grid
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
