I can't wait for the next lot of pictures of some retarded mudflap wrapping their car around a pole just outside the event!
So excitement.
Sometimes you can score some mad parts if you can untangle them from the chain link fence out the front!!
only just found out about this. super busy this week :(
The good news is; it's not too late to flip your car upside down in a garden bed and blame "Cold tyres" for the whole thing.
You might be pressed for time to get the single pegger diff and steelies fitted though. ;)
  • Like 1
after seeing and reading things that go on at these type of events, has really deterred me from going, even just to spectate.
For now, I will stick to sau events, as I know they don't tolerate stupidity.
I may check them out one day, when they have seemed to mature a little.
  • Like 4
100 points to Dale. Sorry for crappy photo - had to rubberneck.
Incase you cant make it out, its a Supra and the location is just outside the gate at WSID
I was returning home from a family function.
  • Like 5
Is there an increased police presence during EOMM?
Absolutely.
Not only on Ferrer's Road but at the nearby M4 entrance too. A few cars got caught last night as well.
The Highway Patrol Command HQ is nearby as well..
everytime i have been to the drags on wed night people leaving always drive like idiots.
The road surface is less gripper then the 1/4 mile track. Hence it doubles or sometimes triples their car's power output which makes it easier to chirp 2nd gear leaving the gate.....and then straight into it for some.
The only reasonable logic I've come up with so far..
  • Like 2
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
