Hey everyone,
My name is Sammy and I bought my first nissan, a 1991 Nissan Skyline GT-R about 5 months ago. I used to own many ae86s after having enough of rust and leaks, i decided to sell them all and move on to something more desirable, which got me here. To briefly describe my technical skills, I'm good at turning a wrench but an amateur at diagnosing.
After driving the vehicle for a few weeks, I noticed that there was a tapping/ knocking noise coming from the engine. The noise is only there when i cold start the engine. After driving the car from about 15 minutes, the noise is COMPLETELY gone.
Here is the video of the sound: https://www.youtube.com/watch?v=TPS5SNXujHc&feature=youtu.be
(sounds exactly how it sounds in the video. I would turn off the bass on the speakers to hear it properly.)
I've had a various tuner shops have a look at the car and noone would give me even a rough estimate of the problem without asking me to rip apart the engine at their shop for $150/hr. So i stopped driving the car and it's been sitting in the driveway for 4 months now.
Although one person told me that my timing belt is too tight and the oil pumps also make that noise sometimes so I have all those parts on order and waiting for them to arrive.
The car is fully stock. No mods whatsoever apart from a quite kakimoto catback.i am using castrol gtx 10w40 conventional engine oil.
Please help
Edited by gotenek
Conventional oil? As in not synthetic?
What oil?
Hard to tell from the video, but I would check valve clearances first, as it is relatively easy.
If it's a death knock, go hard. If the engine wants to doe it will Wether you like it or not.
What oil?
Yes, non-synthetic castrol gtx 10w40.
Pretty sure don't have forged pistons lol. I dont think the cam covers were ever removed when i replaced the rubber just a few weeks ago.
I just changed the oil to fully synthetic 5W40 for the hell of it. The noise was still there.
So I grabbed a long screwdriver and started poking around the top of the engine with my ear to the other other of the screwdriver.
The noise was about 10% louder than you can hear without the screwdriver on the whole area of the cam covers.
The noise was about 3X louder when I put the screwdriver on top of the top timing cover. I have a plastic clear timing cover ( just want to mention it)
Thus, I'm assuming the noise is coming from somewhere in the timing belt area. Can tensioners make that kinda knocking/tapping noise? Or perhaps the oil pump?
Use the screw driver trick to the ear along the top of the cam cover and front cover.
Also do it to your injectors and around the exhaust manifold (in case you have a seriously odd leak making the sound and heat closes the leak).
Take out your coil packs and check to see if your spark plugs are tight.
doo doo, Unfortunately I'm located in Canada. Thanks for the offer.
I'm going to be pulling the engine and inspect a few things, especially in the head - the cam cover caps. Thanks for all the help everyone.
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
