r32gtstJ Posted August 28, 2015 Author Share Posted August 28, 2015 Is there something for the cold start?? Where is it? The car has no issues in idle so I don't think it's the iacv but it's just really hard to start sometimes over 3-5 seconds of cranking before it starts and sometimes as soon as I turn the car on, it's on.. I'm puzzled Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7594938 Share on other sites More sharing options...
Hadouken Posted August 28, 2015 Share Posted August 28, 2015 Is it temperature related? Ie. How cold is it outside when you are experiencing these problems? Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595006 Share on other sites More sharing options...
r32gtstJ Posted August 28, 2015 Author Share Posted August 28, 2015 It's about 5-10 degrees Celsius at the moment and it sometimes fine from dead cold and after driving about 15 mins and restarting it cranks for longer than when I initially started it from cold Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595007 Share on other sites More sharing options...
r32gtstJ Posted August 28, 2015 Author Share Posted August 28, 2015 I thought it would be weirder if it has problems starting when warm but that's the way it is at the moment. But it never failed to start yet, just needed to give it a bit of throttle and it goes... Just annoying and don't wanna strain the starter motor that's all if this continues Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595008 Share on other sites More sharing options...
tridentt150v Posted August 28, 2015 Share Posted August 28, 2015 best way to warm a car up is to gently drive it...that way the gearbox, diff, power steering whatever also get to warm up. Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595014 Share on other sites More sharing options...
r32gtstJ Posted August 28, 2015 Author Share Posted August 28, 2015 Yeah, I learnt that yesterday from other members comments so I'll be doing that from now on, It's fortunate I only had the car for a few days and fix bad old habits. Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595015 Share on other sites More sharing options...
Hadouken Posted August 28, 2015 Share Posted August 28, 2015 That's not what he is talking about now lol Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595016 Share on other sites More sharing options...
r32gtstJ Posted August 28, 2015 Author Share Posted August 28, 2015 Haha any comments welcome but yeah initial power loss/ idle isue is fixed but just the ignition issue bugs me at the moment. It does have a pretty small battery... Could that be the issue maybe? Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595021 Share on other sites More sharing options...
Missileman Posted August 28, 2015 Share Posted August 28, 2015 (edited) It only needs a small battery, if your battery is in good shape then no it will not be that. Edited August 28, 2015 by Missileman Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595023 Share on other sites More sharing options...
r32gtstJ Posted August 28, 2015 Author Share Posted August 28, 2015 Cheers missile man, hoped that wasn't the case because it looks pretty new from Japan. So that ruled out... What can it be, it only has aftermarket intercooler, oil catch tank ( at least that's what I think it is, I'll upload photos later) so don't think it's anything off tune. Engine and turbo is stock Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595029 Share on other sites More sharing options...
r32gtstJ Posted August 28, 2015 Author Share Posted August 28, 2015 Oh yes and an ARC super induction box with a new AFM Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595030 Share on other sites More sharing options...
scotty nm35 Posted August 28, 2015 Share Posted August 28, 2015 Check the fuel pressure on cranking, if the check valve in the pump is faulty it will take a while to prime the rail. Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595036 Share on other sites More sharing options...
Missileman Posted August 28, 2015 Share Posted August 28, 2015 Could be lots of things, from fuel pump to injectors, ignitor module to CAS, Do what Scott tells you, he's more qualified than me. Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595060 Share on other sites More sharing options...
scotty nm35 Posted August 28, 2015 Share Posted August 28, 2015 I just start with the free options to try, and work my way to the expensive parts, unless you can find spares you know work. Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595067 Share on other sites More sharing options...
r32gtstJ Posted August 28, 2015 Author Share Posted August 28, 2015 Ok thanks for that, I'll try the ones that don't need parts first~ the AFM install cost me like $400 already.. Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595122 Share on other sites More sharing options...
r32gtstJ Posted August 29, 2015 Author Share Posted August 29, 2015 Just confirmed, it's worse when the car is warm. It starts fine when it's cold... I'm puzzled... I thought it would be worst in the opposite situation. Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595456 Share on other sites More sharing options...
Hadouken Posted August 29, 2015 Share Posted August 29, 2015 Cas Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595483 Share on other sites More sharing options...
r32gtstJ Posted August 29, 2015 Author Share Posted August 29, 2015 ah! Cam angle sensor.... that makes sense, ill have a look in to it. thank you Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7595556 Share on other sites More sharing options...
r32gtstJ Posted August 31, 2015 Author Share Posted August 31, 2015 hey guys, I've posted some new pics on the forum http://www.sau.com.au/forums/topic/459359-back-again-with-a-new-ride/ does anyone know what the can looking thing in the 7 th picture is? Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7596262 Share on other sites More sharing options...
tridentt150v Posted September 3, 2015 Share Posted September 3, 2015 That's not what he is talking about now lol Yeah, thats just me.....a day late and a dollar short Link to comment https://www.sau.com.au/forums/topic/459260-r32-gts-t-problem-losing-power/page/2/#findComment-7597614 Share on other sites More sharing options...
