Ok so still some room for improvement. I'll have to see what can be done about that.
27 rwkw increase, might get another 5 or 10 with leaner mixtures ??
I'll scan the graph in at work tomorrow. Power curve looks quite fat to me.
Abo Bob, good work and good to hear its going well.
666Dan, very interested to hear what you can report on the ingnition harness.
FYI, my GTT has been running EManage (minus ignition harness for close to 2 years now and i am very happy with the result and response...no auto issues to date with crisp, fast changes but am considering auto mods such as altering stall etc. Current set-up: Hybrid FMIC, Hi-flowed standard turbo,Emanage,AVC-R (running 1 BAR), K&N Panel filter, Z32 AFM, 3" Dump, 3.5" JASMA exhaust and 3" CAT back, current power 220rwkW...am fitting Walbro internal 255lph fuel pump and searching for a set of injectors....
Cheers,
Michael
Just an update for the people that didn't see my post in the e-manage thread....the ignition harness works if a 3.3V Zener diode is wired in reverse bias with the ignition signal wire.
If anyone needs more details just PM me...I'll probably post a diagram of it as well.
It's great now I can actually alter my ignition timing :)
It's great now I can actually alter my ignition timing :(
Hey Dan! if you dont mind me asking how much did you pick up the emanage and wiring etc.. for?? hehe Ive got a power fc sitting here right now that I cant use (dammit)
You can get the e-manage for $700 delivered, this is a full kit including software for a laptop.
And contrary to belief the shifting is not affected at all, I'm running an N/A computer with boost, so my ignition curve has been messed with drastically from the factory values and it shifts as sweetly as it ever did.
This is my understanding of "full kit" with prices as at yesterday;
1. E-manage main unit
$US295 = $A415
2. E-manage Support Tool
$US119 = $A167
3. Optional Injection Harness
$US32 = $A45
4. Optional Ignition Harness
$US34 = $48
Package $US449 = $A632
+ Freight $A100
+ Duty 15%
+ GST 10%
That’s $A926 in total, or have I missed something?
The whole package delivered is actually US$500 (inc freight) which is ~ AU$690, customs & GST is a strange one, as my package was opened & inspected by australian customs and sent on it's merry way to me without ANY additional cost.
The support tool is readily available as a *free download and clone USB cables can be had for US$50 this will also bring cost down a bit.
Dan
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
