Greetings from Holland.
Im new here but I wanted to share my car project with you guys :)
Registered some time ago and came here because of the massive BW EFR tread haha.
Been reading a lot and now I think its time for my project tread to be put on here.
There is no real deadline since im pretty bussy with work the last year so there is no real progress made since half a year ago only scavenging for parts.
So here's the story.
3 year ago I purchased a crappy r33 gts-t.
Engine needed to be swapped because the other one was crappy.(died after the first month and hardly driven it)
Some pictures of the car and blow and other engine :)
Engine RIP :'(
So I bought a rb25 with forged internals.
cp pistons/eagle rods/arp studs/acl bearings/steal headgasket.
Did some driving around for almost 2 years without any real mods and then after 2 years the clutch was beginning to slip.
After some thinking and going to events where they had track days and time attack I made the choice to build myself a fast weekend/trackday car.
Befor I put the car away for a while so I could save up for some money for the parts I went for a engine checkup and with that checkup it came clear that it was better to rebuild the engine.
Compression and leaktest shown that it would be better to do so and there were some marks in some of the cilinder walls so there goes Bore 87mm :P,
So I brought the car to a mate's race teams warehouse where he is head mechanic and left it there for a while so I could save up and work on it when we had the chance to.
The main thing about this project is that I want to do all the things myself that I am capable of, and if not my mate will be standing by.
We cant do everything ourselfs but what we can do will ultimatly save a lot of money.
So when im not that bussy at work we will yank the engine out and start rebuilding.
Car will be build for street/circuit(trackdays)
Power goal 650hp and anything above will just make me happier :D
Speclist for engine how I see it(may change a little depending the wait of the parts)
RB26 crankshaft balanced
JE pistons 87mm bore (rb26)
Cometic head gasket (size ?? )
Eagle H beams
ACL bearings
Borg Warner EFR 8374 IWG
6boost manifold
3,5" exhaust system
Greddy intake
N1 waterpump
Nitto oil pump
Topfeed fuel rail
1000cc injectors (if e85 I need a bit bigger)
Fuel system still under advisement thinking about Holley dominator 1400 pump
modified oilpan
Xtreme clutch 230mm
Head
Supertech single springs
Camtech 268* 9mm
HKS exhaust gear
HKS belt
Custom rockerscovers with an10 fitings at the back and copied Mine baffle plates installed
Cilinderhead ported/polished
Ecu thinking about Link g4.
With the chassis, exterior and interior.
Still road legal
Chassis will be stripped down.
Rust will be cut out and welded
Rollcage (maybe bolt in)
Bodykit Vertex with rocket bunny v2 style fenders
Custom made rocket bunny style drift wing
Colors some mix of black and orange.
Cosmis wheels
JBT big brake set 355mm 6pot front and 355 4 pot rear.
Driftwork arm kit
Lots more that I cant think of anymore.
Pictures of taking out the engine
(wings are rotted to the chassis :P will have to take a flex to get them off haha )
So this was one of the last steps till we both had no more time on our hands the last 6 or so months.
To busy with work and other stuff.
So on towards some of the nice parts I have been collecting for the build.
Here is the Nitto oil pump
JBT big brake kit
6Boost manifold (real piece of work)
And last but not least the master piece.
Borg Warner EFR 8374 IWG next to the 7670 which i bought on impuls (it fits my nickname)
So this is what I have up to today.
Yesterday the deal was made with garage7 for a set of Camtech rb25 vct cams 268/9mm which will be here in about 3 to 4 weeks.
When its a bit more quiet at work afther the summer is over I will go and take apart the engine and take the engine to a machine shop for the overbore and valve angle job of the head.
This is it for now.
Hope to keep you updated as much as possible.
Greetzz
Ps. please dont be a grammar nazi (I did my best with my English :P )
Edited by Impulse-NL
  • Like 4
https://www.sau.com.au/forums/topic/459302-my-r33-gtst-weekendtrackday/
  • 4 weeks later...
So I just received my cams and im not really happy.
I mailed with garage 7 for a set of cams with vct option and asked a couple of times about it and they confirmed that it was possible to get these.
When opening the box it became clear they were not vct able :(
As you can see both for adustable camgears.
Have mailed Evan @ Garage 7 already and hoping for a good solution because I just payed 180+ euro's import tax for these cams that are not right.
  • Like 1
Good news regarding the cams.
Camtech agnolished their mistake and is making an intake cam to send to me when its ready.
Good and fast service from Garage7 and camtech.
In 2 weeks im going to rip apart the block and hope to get it machined the same week (if possible)
  • Like 2
  • 1 month later...
So last week I got the VCT intake cam from Camtech :) this time it was the right one :D
Yesterday we disassembled the engine and messured the cilinders.
Cilinders were in very nice shape even the bearings looked perfect as did the pistons(apart from some carbon buildup)
But there was a feelable mark in 1 of the cilinders (that were seen on an engine check some time ago)
This was one of the reasons I wanted to freshen things up and bore 87 and oversized pistons.
Next week im am going to clean the block and measure for the right size of bearings for the rb26 crankshaft.
  • Like 1
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
