Hi.
On my R33 GTR which has done 100,000km, I have noticed it has a very unusual power delivery mostly when cold, it seems as if the power curve flatlines for a bit, and then surges suddenly, I can feel/hear very feint misfiring, but most of the times it seems like somethings holding back, you can notice it when you hold the throttle at say 40% in 1st or 2nd gear. It get's better as car warms up.
Now I'm thinking first thing most people would say is Coilpacks, am not sure how they play up on these cars but I'm thinking those would cause severe misfiring under high load all the time, which I don't get, could it still be coilpacks?
2nd Issue I have heard could be AFM's, I have opened them up before to add solder the the joints which is a common problem. The elements on the AFM's appear clear with no buildup.
Igniter is recently changed off a car that had no problems.
I had it in at a GTR Specialist and they said some of the injectors may be dirty which is causing a bit of a rough idle and coming onto power badly.
I would appreciate any feedback or experiences you guys have had with an issue like this.
Cheers.
  • Like 1
If it only does it while the engine is cold, then I wouldn't worry about. You really shouldn't be using "power" on a cold engine.
Edited by blind_elk
Have seen afm's that look practically new and be no good...not saying this is ur problem tho as it probably wouldn't change hot r cold...could be fuel delivery alrite...what work have u got done recent or how long I this happening?
  • 4 weeks later...
It happens 80% of the time when cold. I have not had any work done on the car recently.
It definitely doesn't feel right.
On rare occasion when cold the revs would play up a little bit, slight misfire, but most of the time it's unusual jerky power delivery.
Edited by RB335
  • 3 weeks later...
[img4]http://i.imgur.com/reqcct we x[/img]
2
My 32 gtr daily has just had the exact same symptoms, did you find a cause?
When cold the power is hesitant. Not on boost just on gentle power then it sudenly releases and its smooth again.
I now and suddenly get it occasionally when crusing allong, it feels like it starves for fuel or air sligtly then releases. No issue at all on boost or wot.
Im running stock ecu, stock engine rb26 and although i have had no issues prior and no change and i daily the thing so i know, something has deteriorated. What should i check first?
Plugs or coilpacks, even injectors pumos and so on would have to give me issues on wot i would have thought?
Im guessing something more electronic like cas or afms, can i trouble shoot these somehow when its such an intermittant and specific issue?
Edited by GH05T
  • 1 month later...
I could not find the issue.
I notice that also when the car is fully warm on a midly hot day, it can be slug when you put your foot down in 1st gear, but if you let the revs sort of build then punch it, it goes better. I have no idea if knock sensors are detecting pinging or going off randomly and pulling the timing or not.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
