Hi all,
I have a r34 gtt with a gtx3076, link ecu, Walbro 450lph fuel pump ect.
Anyways its time to upgrade the injectors, I want to put something decent in which will allow me to run E85 down the track without needing to change injectors again. I will need to upgrade the pump & lines when the time comes.
I am looking at these deatschwerks 1000cc E85 compatible injectors:
http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/neo-rb25det/1998-02-neo-rb25det/17u-06-1000-6-detail
Now the question is, are these going to be ok to run 98 pump fuel through without having a shocking idle & part throttle drive ability?
If its going to make the car real rough then I think I will need to go smaller now & then upgrade when I do want to go E85.
Sorry if this is a newb question, I have done some searching but cant find much.
Thanks in advance.
https://www.sau.com.au/forums/topic/459340-98-octane-through-1000cc-injectors/
They are a high flowed Bosch 550cc injector, so there are better options for 1000cc injectors available now.
http://www.nzefi.com/product/nissan-rb-1000ccmin-top-feed-direct-fit-fuel-injector-kit/
Thanks for all the help.
Sub boy32 are you saying those deatschwerks are actually high flowed 550cc bosch injectors?
Wheezy what brand injectors did you fit?
What sort of power are you guys running on 98?
I wouldn't stress too much, most of the 1000's sold these days are 750cc injectors with the pintle cap removed. They spray perfectly well, and work better for e85 imo than the long nose 900cc injectors he linked, and cheaper.
Marketing hype...
Id1000
With the dollar the way it is, locally modified and warranted injectors are a much smarter option, considering they are exactly the same Bosch injector. Unless you like paying the ID tax...
The new 1300 and 1700s from ID are a whole new ball game though, internals are made inhouse with BOSCH motorpsort department... they are streets above the rest ATM.
The 1300's are only available through ID, but the 1700's are sold locally also. Not cheap though.
I was hoping to try them out in the evo but the 1400's I have currently will be fine with the Haltech elite i'm sure, and nearly half the price.
I wonder how much different they are from the stainless Deatscheworks...
http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/rb26dett-skyline/1989-2002-rb26dett/1200cc-fuel-injectors-6-detail
http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/rb26dett-skyline/1989-2002-rb26dett/1500cc-fuel-injectors-8-detail
Marketing hype...
We have done quite a bit of injector testing.
The spray pattern between a high flowed 550/750cc injector compared to the ones I have linked to are night and day different
The Bosch 1000's are designed for Ethanol, where as the 550s weren't......
High flowed injectors were fine when there wasn't the correct sized injector available.....but now Bosch makes 1000's, 1300's and 1650's straight out of the box now.
Edited by Sub Boy32
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
