I was planning to change the timing belt over the weekend (first time since I have had this car) and when I got to the harmonic balancer the bolt was loose and the balancer is stuck on.
My concern is that the key way is bent, basically I was putting as much force on the puller as I could with a 1/2 inch ratchet, and wasn't game to try with a breaker bar.
Now I'm wondering whether I just leave it as is until the water pump or timing belt goes and then rebuild or do I sacrifice the balancer and puller to get it off and hope the crank is ok.
Any advice or tips from anyone who has been in this situation would be great
https://www.sau.com.au/forums/topic/459352-rb26-harmonic-balancer-stuck/
Try using some WD40 on it and leave it for a while to penetrate??
Also maybe Freezer spray???
Never had it before, but just thinking of other bolts and pulleys/cogs and how I've got them off and Oxy warming is prob not a goer for this one lol, although I have heard of jugs of boiling water being used.
Yeah I will try lubricating some more - main concern is that the key way is damaged and if I force it off I will be up for a new crank.
I was using a bolt type puller but it looks like someone else has had a go with a claw puller because part of the lip on the front has been snapped off
OP mentioned Bolt was already loose, ill bet key way and key is damaged.
Get the best puller you can and have fun now.
Dont let it go till the belt breaks......valves will meet pistons.....
I hate to be captain pessimist but there is a bloody good chance your oil pump is on it's way out too.
On RB's loose balancer bolt quite often leads to shattered oil pump. Happened to me and a few others I've about.
If the balancer bolt was loose often the balancer will flog out the key way as well as the key.
Then the balancer can rotate slightly and jamb on the remains of the key.
I'd persevere with decent puller bolts.
Easier to do this work in-situ than chasing an engine around the shop on a stand.
  • 3 months later...
i am picturing some king of clamping mechanism locking a router type tool into place on the crank
Yep, but good luck getting it close enough into towards the block with the motor of the router in the way.
Only way is crank out and CNC or manual mill a new one in.....
It can be done by hand, if your just fixing it to sell, but good luck to the poor sucker who gets stuck with it.
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
