hi all! just wanted to say hello again, I joined SAU 6 years ago but since then alot has happened and
I sold my Skyline R32, which I regretted.
Now i'm back with my fresh new import!
I've been wanting to get another R32 for a while, and found this 1993 GTS-T with genuine 67km on the clock!
It seems like it had a few minor mods like Greddy Strut brace, ARC super induction box, Sickspeed oil reservoir (still dont know what it does)
and aftermarket intercooler.
Look forward to making it a daily driver, not after ridiculous power, and want to leave the engine alone as much as possible.
I like a quick spooler.
planning on a Nistune + Z32 AFM upgrade with a HKS 2530 if I can find one..... but seems non existent these days,
If anyone has any sggestions, please let me know
https://www.sau.com.au/forums/topic/459359-back-again-with-a-new-ride/
get an alarm system, dash mat, and use a sun reflecta on your windscreen when parked up outside
you have a good dash pad so may as well keep it good, mine has just started to bubble in the vinyl and I'm pissed orf about it.
I dont think I will, its not like i'll boost unnecessarily in town,
I think turbo timers are rarely needed for a daily driver to be honest
Anyone have tints on their car?
I heard its pretty good for uv protection and heat minimization as well..?
I've read up on some articles and most will probably agree the rb engines don't have the greatest design when it comes to the reliability of cas.
What would be the most cost effective way of reducing this problem?
Would it be worth installing a trigger wheel of some sort?
The car starts fine when cold,
But when it's been driven for a while it seems to take longer to start thereafter, so hadouken suggested a possible cas issue.
I just wanna see if there are any options before I go out and buy a new cas that costs around $500 just to see it have problems in a year or two
Go post in the NZ forums and see if there is anyone near you how has an rb20 in good working order and is prepared to help you fault find. Then you can start swapping bits over in a process of elimination.
there's a fellow in the forced induction forum that sell his own design triggers, he's one option, but first have you to make sure that the cas is the fault.
Edited by Missileman
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
