Hey guys,
I've owned a V35 350GT sedan for 2 years now. Ever since I bought it the I knew the clutch was eventually going to go. I just recently (8 weeks ago) had a new flywheel and clutch installed and a wheel bearing replaced ($2500 total!!!). Since yesterday my car is making some noises.
There are 2 noises I can hear that sound peculiar.
Noise # 1: If I am sitting idle in neutral and when I disengage the clutch a whurring noise CUTS IN but when I engage the clutch it FADES OUT. Its not too loud but I only heard it because I was in a KFC drive thru next to a wall where the sound reverberates off the wall.
Noise # 2: Every time I go from idle or almost idle and then accelerate in either 1st, 2nd or 3rd gear there is a grinding/whurring sound which kicks in about half a second after the clutch is disengaged.
I took it back to the same mechanic that installed my clutch and flywheel and he says "The car has had a hard life and now all the issues are coming to a head and it is an engine issue, not a clutch issue". He thinks it is 'endfloat' issues with the crankshaft, meaning there is movement in the cranshaft back and forth. I just don't know whether he is talking shit because he was the one that installed my clutch and doesn't want to own up to any shitty work he did or whether he is properly diagnosing it.
I was wondering if anyone can:
1. Shed light on this mechanical issue or
2. Recommend a good mechanic in Brisbane area that can give me an honest, objective opinion.
Thanks in advance
Blake
Did he swap out the Dual Mass Flywheel with a Single Mass? If so, extra gear noise is normal, especially at low RPM is normal.
But it depends on what you mean when you say 'clutch disengaged'? does that mean clutch in, or out?
Even with the stock DMF, you will get some gear rollover noise at idle with the transmission in N and the clutch out. Usually only noticable when you are next to a wall or other object to reflect the sound.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
