Looks like I managed to create a discoloured hard patch of leather after having an accident with the contents of a DampRid moisture absorber while the car was in the garage for a few months. Needless to say, I'm pissed off with myself and even a few hours soak of my Meguiars leather cleaner/conditioner hasn't done much to restore it to any degree.
So I figure it's probably best to just replace it. Thankfully the backrest is unaffected. Anyone got a black one in excellent condition (as mine once was until now) they'd like to sell? :/
Many thanks mate. Hopefully this one can be saved because DampRid, like most moisture absorbers, is a caustic soda, from what I understand. :/
Still, I'll give him a shot before I call Raj at Steve Jarvin for a replacement seat. It's much appreciated!
Looks like I'm calling Raj. It's too far gone. Let that be a warning to anyone else who uses moisture absorbers, like DampRid, etc. I'm keeping it on the floor like I used to. At least I can easily replace floor mats. :/
  • 1 year later...
Apologies for resurrecting this thread but for the sake of relevance, I'm sticking to it!
So it turns out Nissan in Melbourne finally got back to my contact and advised that a complete rear bottom seat assembly is no longer in production. I'm having a very hard time believing that for a seven year old vehicle, personally. I'm thinking of going through Amayama and see if they have better luck than I do. Anyone have any experiences with Amayama they'd like to share with me before I go forking out close to $2k for a seat?
I have used Amayama plenty of times without issue, but not for anything that large, postage is going to be a killer.  If they have stock in UAE, it is usually considerably cheaper for the item, but postage will be considerably more than Japan.
Have you tried an auto upholsterer?  it will likely be cheaper to have it re-upholstered than replacing it.
It will be marginally cheaper, however, the problem may possibly be that the caustic Damp Rid may still be lurking in the foam padding and if it is, it'll just destroy that leather trim as well.
I'm thinking of checking out some local wreckers for any reasonably pristine candidates but failing that, I'll be looking for something new, albeit with the massive expense in shipping the damn thing. :/
Looks like after busting balls a little more, Nissan Australia (Melbourne) got back to my guy at Steve Jarvin and they do have a trim assembly, which is basically the seat without the frame. It's just a matter of unclipping the old seat from the existing frame and clipping the new one on in its place. Hopefully they're right because it's a $1080 mistake if they get it wrong for me.
Still, I'm pretty chuffed to hear about that and I can finally restore Max Jr back to normal. Let's see what happens when it finally arrives in a few months (sea freight).
  • 4 months later...
Looks like Nissan Australia got it wrong and sent what was only the leather trim but not the cushion as well. Steve Jarvin's boys (sadly, Raj is no longer there, so there goes any reliability from those guys too) are supposedly being told by Nissan (Melbourne) that now even that trim is no longer stocked in Japan. I suppose after eight years, they can only carry so many spares but the parts are dwindling fast for these vehicles.
So my options are two:
  1. Seek out a wrecker in Sydney with a suitable seat
  2. Try out Amayama
I've lodged an order with Amayama to see what they come back with for the entire seat assembly, at almost double the cost of what this trim order was, which thankfully I'm not paying for. Anyone dealt with them before? Anything you can share about your experiences or what you've heard would be nice.
Otherwise, anyone know of a decent wrecker in Sydney for Nissans/Infinitis? At this rate, I don't care if it's not the exact same design as long as the colour is still black. I've been out of the spares game for a while when it comes to wreckers, so I'm open to all suggestions.
  • 3 weeks later...
Final entry in this saga. Even Amayama can't score one. I realise the car is eight years old but I expected a little more support than that. According to Nissan Australia (Melbourne), even the Infiniti seats won't fit because there's a difference in the floorpan where the seats clip into, etc. Smells of bullshit to me but there you have it.
So I'm getting my mate to pick up the $1000 leather trim that he was able to obtain, thankfully, and I'll find an upholsterer who can fit it up for me when I get back from my work overseas. With a bit of luck, maybe the existing foam will be salvageable in that either the caustic liquid never made it past the leather and into the foam, or otherwise the foam can be cleaned up reasonably well to avoid a recurrence.
Valuable lesson learned.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
