Guys for those that are on fb here is link....
https://www.facebook.com/groups/wajcc/702351913200261/?ref=notif&notif_t=group_comment_reply
For those that aren't here is description of ad... Original motor and head
95 v spec. Immaculate inside and out. Bilstein coil overs. Tomei Ti expreme cat back. 3 inch HPI dumps into 3.5 inch front pipe.
Fresh forged built engine with spool rods and cp Pistons and rings. Reimax oil pump gears. Mines cam baffles. HKS 272 cams. Super tech valves guides and seals. Ported head. HKS 1.5mm head gasket. HKS intake and exhaust manifold gasket kits. Garret 2860-5 turbos
Power FC with hand controller. HKS boost controller.
120,000 Ks. All original paperwork. Tomei cam gears
Split fire coil packs
Have 1250cc injectors, nismo afm's, walbro 460 pump and turbo smart fuel pressure reg on order at moment then it's full tune time. (included in Tuned Price).
Built with cp Pistons 86.5mm
Spool h beam rods)
Tomei 1.5mm block oil restrictor
ARP bolts throughout
Nismo copper mix twin plate clutch
Momo Race steering wheel
alarm and immobiliser with shock sensors
keyless entry
Probably lots iv missed
Made 325hp at all 4 on 14psi at 6000rpm limited and 620nm while checking afr's
Comes with stock steering wheel and suspension
$28k with out added parts that are in order mentioned above.
Still on run in tune.
Will be tuned shortly
What do you guys reckon is it a good buy??????
https://www.sau.com.au/forums/topic/459389-thoughts-on-this-r33-gtr/
Yeah he said it will need a further tune seller said he changed the down pipe to a 3 inhch or somat and its now making 378atws.. I am guessing that figure is still pretty low considering the build hey??? is only done 700kms since build hima nd his mechanic mate did it but he is happy to get me further compression tests results with proof for peace of mind for me
Build without receipts, bring it to Galvsport or similar for a full check imho.
Yeah power was a little low but its running stuff all boost too.
Get it checked over and pay what you're happy with.
Like I said, I personally feel its expensive for a 33.
Hey updating this as seller has just got back to me saying he has just had a walbro 450 fuel pump put in and re-tune (2 tunes now) low boost 14psi and high boost 19psi, 19 psi is putting otu 450 bhp atws. does this sound about right???
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
