Guys for those that are on fb here is link....
https://www.facebook.com/groups/wajcc/702351913200261/?ref=notif&notif_t=group_comment_reply
For those that aren't here is description of ad... Original motor and head
95 v spec. Immaculate inside and out. Bilstein coil overs. Tomei Ti expreme cat back. 3 inch HPI dumps into 3.5 inch front pipe.
Fresh forged built engine with spool rods and cp Pistons and rings. Reimax oil pump gears. Mines cam baffles. HKS 272 cams. Super tech valves guides and seals. Ported head. HKS 1.5mm head gasket. HKS intake and exhaust manifold gasket kits. Garret 2860-5 turbos
Power FC with hand controller. HKS boost controller.
120,000 Ks. All original paperwork. Tomei cam gears
Split fire coil packs
Have 1250cc injectors, nismo afm's, walbro 460 pump and turbo smart fuel pressure reg on order at moment then it's full tune time. (included in Tuned Price).
Built with cp Pistons 86.5mm
Spool h beam rods)
Tomei 1.5mm block oil restrictor
ARP bolts throughout
Nismo copper mix twin plate clutch
Momo Race steering wheel
alarm and immobiliser with shock sensors
keyless entry
Probably lots iv missed
Made 325hp at all 4 on 14psi at 6000rpm limited and 620nm while checking afr's
Comes with stock steering wheel and suspension
$28k with out added parts that are in order mentioned above.
Still on run in tune.
Will be tuned shortly
What do you guys reckon is it a good buy??????
https://www.sau.com.au/forums/topic/459389-thoughts-on-this-r33-gtr/
Yeah he said it will need a further tune seller said he changed the down pipe to a 3 inhch or somat and its now making 378atws.. I am guessing that figure is still pretty low considering the build hey??? is only done 700kms since build hima nd his mechanic mate did it but he is happy to get me further compression tests results with proof for peace of mind for me
Build without receipts, bring it to Galvsport or similar for a full check imho.
Yeah power was a little low but its running stuff all boost too.
Get it checked over and pay what you're happy with.
Like I said, I personally feel its expensive for a 33.
Hey updating this as seller has just got back to me saying he has just had a walbro 450 fuel pump put in and re-tune (2 tunes now) low boost 14psi and high boost 19psi, 19 psi is putting otu 450 bhp atws. does this sound about right???
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
