R33 intake pipe $20
OP6 highflow turbo. good condition $700. You will need to get braided oil lines to run the turbo otherwise it'll blow. Stao from hypergear can help you with the lines.
Located in SE melbourne. Mulgrave area.
How long since its been highflowed.. was just about to send mine off to him
It's been a while. I got turbo 2nd hand off sau in 2012 not sure when the highflow was done. I've only put 1000kms on the turbo. Turbo looks to be low kms because the exhaust wheel doesn't have much carbon build up.
Hey man. How much laggier is this then standard? I have a stock RB25 turbo on my 4.2 patrol and I sure don't want it to boost up any later!
Cheers.
Should boost around the standard RPM. Won't be laggy at all FYI
It's definitely laggier than the R33 21u turbo on my R33 rb25det. On a R34 neo engine with higher CR and different head should be closer to stock i think.
