I'm ready to install the stock rb20 exhaust manifold and just wanted a few pointers to make sure I do it properly.
The manifold has been machined so it's smooth and straight. I'm assuming the mating surface of the engine is straight as well...? Chances that it's not are probably very low, but I'll check with a straight edge anyway.
I know the torque specs and sequence, but how should it be done? In one pass, or 2 or 3 passes? Should I torque down in one go, or is it better practice to tighten down evenly, in the correct sequence, once or twice before torquing down to spec?
There are some nuts that are impossible to get a torque wrench on, do I just eyeball it, or is there a special method/tool?
After installation is it necessary to recheck nuts after a few days of driving?
What about things like gasket sealants? Are they overkill? If all surfaces are clean, smooth and straight with fresh gaskets, I'm guessing they're not needed?
Thanks heaps
https://www.sau.com.au/forums/topic/459401-installing-exhaust-manifold-rb20/
I use a 14mm combination open end and ring spanner with offset, the open end just happens to fit the 1/2 drive of my torque wrench, so I set the correct torque and feel how much pressure I need to apply to the spanner before the pin pops.
Then put the spanner on the nut and try and simulate that pressure, go full torque in the recommended pattern, no sealant on the gasket, and always new washers, yokes, studs, and nuts.
I do however use nickle based anti seize on the nuts, washers and yokes.
Edited by Missileman
I'm fairly certain you can get to all the bolts with either a swivel or a wobble extension. I'm not 100% because it was quite a few years ago the last time I torqued up a stock manifold, but fairly certain I was able to get all of them with a torque wrench
Just doing a final clean and noticed the stud holes don't look 100%.
The first and/or second thread of each hole looks slightly damaged, as if things have been over tightened in the past. Is it okay, or should it be fixed?
I'll also clean out the holes thoroughly with a small wire brush, some acetone or brake cleaner, and compressed air.
I.d use three steps to tighten....less chance of distortion or loading up one or two studs - plus even pressure. Also [and I'll prob get shot down for saying this] dont frett if you cant torque down completely. Get a feel for the torque on the ones you can access and just use that feel and the click in your elbow to do those that are hard to access. Torque settings are less critical on something like the exhaust manifold.
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
