shed cleanout part 3 - just recently pulled this turbo off my R33 GTST. It has done exactly 13,981 k's from March 2014 to Aug 2015 (I keep a maintenance log book lol)with oil/filter changed 3 times during that period, turbo still in excellent order and no issues, guaranteed. This comes ready to fit to stock manifold and standard R33 6-bolt dump pipe, but you will need new water lines (about $60 at Enzed, Pirtek etc or make them yourself) as I have used them on the new turbo. The kit from Kinugawa originally isn't quite bolt-on as they claim but is now (with exception of water lines). Included in sale is
- Kinugawa TD05-18G turbocharger, with 8cm exhaust housing, wastegate ported out to avoid boost creep
- spare 10cm exhaust housing, wastegate ported out to avoid boost creep
- 1x spacer plate, port-matched from ex manifold to turbine entry
- 4x longer studs to allow for spacer plate
- 2x dump pipe gaskets, 3x turbine housing gaskets
- 1x Kinugawa adjustable actuator with 7psi spring
- 1x spare Kinugawa 12psi spring
- 1x spare standard shaft nut, 1x spare aluminium bullet-head shaft nut, 1x spare steel bullet-head shaft nut. All new/unused
- 1x oil drain outlet (does not fit R33 oil drain hose, I just drilled 2 new holes in the stock metal drain outlet to make it multi-fitment as shown in pics below, so this is new/unused)
- 1x braided oilfeed hose, with 2x banjo fittings
- 2x banjo fittings>AN fittings for water lines
- 1x silicone compressor outlet elbow to aluminium joiner pipe, to join to your stock piping
$450 for the lot, and can post anywhere in Aus for $30. I don't think you'll find a better-priced turbo upgrade anywhere but if you do, feel free to put an offer in on it.
Kostas - I do my own tuning and don't go to a dyno, so can't say. But you will see them making 230-250rwkw on 16-19 psi.
  • 1 month later...
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
