SAU NSW Golf Day
Event: September monthly meet SAU NSW golf day
Location Map: https://www.google.com.au/maps/place/The+Ridge+Golf+Course+%26+Driving+Range/@-34.031963,150.997167,15z/data=!4m2!3m1!1s0x0:0x7b1f03c8fe1acdec
TIME: 1130am tee off!! Please be there minimum 30mins before so you can pay green fees, hire clubs (if needed), warm up etc etc
Price: Green fees for the day will be $39 for 18holes, club hire starts at $16.50 for half set and $27.50 for a full set
Motorised golf buggy hire is $42 for 18 holes, if you know you want one for the round please let me know so i can have one reserved as they are popular on weekends
Parking: Plenty of parking infront of the golf complex
Spots: We have a booking for 16 people but can increase if we have more but we need a few days notice
Comment below to have your name on the list
The day will also be an opportunity to support a fellow SAU NSW member who is helping raise funds for prostate cancer in the 2015 Distinguished Gentleman’s Ride to help find a cure for prostate cancer
Here is the link to his page where you can make a donation, we will also be taking donations on the day
http://www.gentlemansride.com/rider/troopersr
Hope to see you all there!!!
  • Like 1
https://www.sau.com.au/forums/topic/459437-19th-september-sau-nsw-golf-day/
Reserved for attendees
1. Levinboy
2. Mrfijigold
3. Terry_GT-r34
4. RBrennan25
5. Redline_GTR
6. Deka
7. Crashdown
8. Aggroman
9. Stagea Pete
10. GTofuS-T
11.
12.
13.
14.
15.
16.
Maybe/caddie
1. Yo-Yo
Thanks for the shout out!
Please check out my fundraising page, I'll be taking videos on the actual charity ride day 27th September. Any and all donations are much appreciated and go towards a good cause!
I've never played a round of gold in my life! hahaha, put me down as a maybe depending on numbers :) I'm happy to play caddy and talk about stock options too :laugh:
I am in for this, I actually just rostered that day off work anyway, what a coincidence! Haha. I am by far one of the least talented golfers on the planet so I look forward to entertaining you all with my terribleness
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
