18th October. Smsp North Circuit Interclub Track Day.
I may have big wang by next track day :D brother in law is donating a generic bolt on one he has... now all i need is balls to go with it :rofl: :rofl:
I thought I was getting used to powering through turn 1 (lifting off later, no brakes) until Alex overtook me mid corner :blush:
Lol
What session was this? I'll have a look at the footage.
Lol
I"ll check when I get home, I've still gotta sort my footage
might have been closer to the exit of the corner
I saw you had a bit of a moment in front of fatz into turn 2....
Decent lock up :D
hahaha yeah he scared me :blush:
I figured going off straight would be better than trying to turn too fast and going off in spirals... pretty sure that boiled my brake fluid too, saw some residue on the tank after that session
    • Currently at 380rwkw with 2860 -5's & b cams on e85, trying to make it have a bit more torque/usable power down low.    Ive googled the v cams and most sites say discontinued, is there anywhere you can still get them?
    • Most hardlines are available new still. But unless they're rusted to the point of needing replacement you can just zinc or cadmium plate them to keep them going for decades to come. Regarding the turbo drains it really depends. Braided lines might be better if it's a straighter path than OEM but I would not assume braided teflon lines will never leak. Teflon is a very durable material but you can still abrade, erode, or otherwise compromise its integrity. The return hoses on the bright side are not that hard to access relative to a full turbo removal so if things go wrong you can always put it back to stock. You can very easily drive yourself insane analyzing every little change, or maybe that's just me.
    • ...gearbox connector... CD06 -- solenoid A
    • Very happy with mine and I think you will be hard pressed to find someone that isn't happy after installing.  Is it the best value for money vs other mods (eg 2.8 stroker) hard to say.  If you are building an all out power motor above 1000hp+++, it's probably not for you as you will want bigger cams.
    • Cheers man, I'm almost a little bit relieved in a way. Let the trouble shooting begin!
