I am currently interested in buying a E60 , can someone advise on reliability , performance and maintenance .
I have done a fair bit of research and always looking for more info from an actual owner .
To buy one they are basically the same price as an R34 GTR .
:Mosselman_Chip_Tuning_BMW_M5_V10_507pk_.
  • Like 1
yes a mate has one, i have driven, fantastic car awesome daily with some great performance on tap.
is a great car, however you need to be a bit thrifty on spares or you will end up paying a mint i.e. obtaining parts from the USA on them as local dealers will f**k you in the ass for it.
  • Like 2
Was always wondering where the best place is to source parts if i go down that path . Brakes rotors and clutches are ridiculously expensive to replace .
Also unfortunately private BMW mechanics take the piss as well with repairs , realised this from owning an old Porsche .
yup dude i know with one does alot of the work himself,
even fitted a gintani blower kit himself as no one else has the expertise to do it really
got a whole new rear subframe, diff etc from the USA for $600 from memory so he could fit his new diff gears and have a drop out / bolt in change over of diff gears.
Have you got a fault code finder to plug in? It'll also need to be relevant to the E60.
Yes , will get one if i buy an E60 probably a smart idea . You've owned BMWs Terry ? I remember reading somewhere .
God I love these. Can only imagine how thirsty they are.
Yeah , the V10 sound is amazing the E60 has the same Litres /100kms as my Land Rover about 15 .5 L / 100kms , thats at best .
Lol at fuel economy. Mash the pedal with a smile and curse the bowser lol
Lol . Test drove a 2006 E60 today , they are surprisingly quick and a really hard ride for a BMW ..............Enjoy that fuel consumption .
  • Like 1
Have always had a real soft spot for these. Would love to see how your findings go. Found Pelican Parts in the USA pretty good for info / guides and parts for BMW. I have a little e36 325i and the guides were invaluable. Have heard much the same regarding servicing etc being insane. If you're handy I imagine you could cut costs quite a bit. No idea on Adelaide however I've found one or two euro mechanics in South East Melbourne who weren't just running the shop to rape and pillage every customer.
Have a heap of parts listed for e60 M5's. - http://www.pelicanparts.com/catalog/SuperCat/4121_catalog.htm
Pretty sure I've watched this YT clip of an e60 with Meisterschaft exhaust about 100 times. Jizz.... every.... time.... -
  • Like 1
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
