Hey guys new to the forum and I've started modding my R33 GTST, so I've decided to go with the flex fuel option with the Link G4 ECU that's I've bought.
I've also bought a Walbro 450 E85 fuel pump.
I was recommended to get this fuel rail and injector package by my tuner so I want confirmation from you guys whether or not I should get it.
Mods are: pod filter, front mount, stock turbo (stock boost), 3 inch straight through exhaust with a decat, one hot dog and muffler.
11182225_1038655736147658_76848444121649
For stock plenum. Top feed 1000cc injectors.
Edited by Dan93
https://www.sau.com.au/forums/topic/459479-fuel-rail-and-injector-choice/
Definately the best option going with that for the injectors only thing you will need to change on the aeroflow rail kit to fit the 1/2 size injectors on stock manifold is smaller spacers (8mm) and Orings for the plugs that go into the stock manifold are to big so you need slightly smaller diameter Oring.
Easiest way is talk to Scott on here or look at hes site http://scottyscustoms.com.auhe will sell you the kit with everything ready to bolt in at a good price.
  • Like 1
Ok well the kit consists of everything specifically for the RB25det non NEO, so I would assume that everything that is in that kit is perfect for it.
Has anyone used this kit yet? Also it's $750. Does that seem to be a decent price for what it is?
Quite a bit of money for a modest performance increase (based on running E85) . You will need a retune. Why not wait until you get a new turbo? The new rail is not necessary but if you want one its not that expensive I guess.
Hasn't been tuned yet as that ECU isn't in yet. I'm doing the fuel setup beforehand so it gets done in one go with no retune needed.
What do you mean "I'm doing the fuel setup beforehand so it gets done in one go with no retune needed" ?
Does this mean you plan to drive around for a while with these injectors in without tuning it?
I will either drive the car to the tuner and install it there or I will do it all at home and then get it put on a tow truck and taken to the tuners.
That kit won't just bolt in, not unless they have made different rail spacers. Do you have a link? Where is the kit from?
Also the lower plenum adapters won't fit into the stock plenum without changing the Orings to thinner ones. The rail kits are designed for Greddy plenums.
Ah, Garage7 in the watermark. Ring them and ask? I doubt they will know what you are talking about, and it will be your mechanic's problem when it doesn't fit, which you will have to pay for.
Alright guys thanks for the help. Has anyone dealt with garage7 in Adelaide before? They seem to be pretty damn good and a lot of help.
If you're on Facebook do a search for garage7 and look at their photos. Says it's a solution for stock plenum on rb25dets non Neo conversion from side to top feed.
Just looks like an Aeroflow rail kit to me, unless the pictures don't show the short spacers and second set of Orings?
I can only assume Garage7 are buying the whole kit including injectors from Aznew, which is my supplier, and they don't include either. I need to make the spacers to suit the short 40mm injectors.
Call them and ask, it's the only way to be sure.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
