Alright guys! You've been a huge help! My main concern was whether or not they were trying to rip me off and trying to sell me something that I don't need.
My main goal is to have some nice power for the hills (I don't drift the car, not into that) and a good suspension setup.
Plus I want to keep the engine bay mainly stock looking and clean.
I know very few people who have ever had an issue with garage7. They are a great supporter of R chassis and make loads of custom parts for them. Decs is super switched on and knows his shit, I can't imagine him selling something that won't work :)
Exactly my thoughts man and thanks for the input! I obviously want to do my homework so I don't buy into something I don't understand.
Also, from what I've read is that I've got to replace the rubber fuel lines because it breaks down and clogs fuel components. Do it once do it properly.
  • 4 weeks later...
550 is the largest side feed my wholesaler can get, so anything larger than that is 'highflowed' with a drill bit.
They are still 20+ year old design, even if you buy new. Nothing that old compares to a modern Bosch injector, in fact not much compares these days. If you are planning to run e85 one day you have no real choice but to do a top feed conversion, the sidefeeds won't last long on e85 from my experience.
I just don't want to go top feed because I want to keep it looking stock.
I've got a couple friends running sidefeeds on E85, but have them going at 100%. They're runnning close to 300kw though. That's not my goal.
You can barely even see the top feed rail when you have the std plenum and cross over pipe it does look stock.
I would personally save a little more and buy a billet performance product fuel rail and set of siemens deka injectors if using e85 or bosch injectors if using petrol.
I wouldn't touch that Chinese junk after reading about first hand experience on another forum.
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
