After seeing the demon eyes in my build thread a user (Adz2332) from the forums contacted me to do a budget RGB demon eyes and black out to stock projectors.
Thought id share the results :yes:
below if a sampling of the colours it can produce. (test were done just powered by a 9v battery so with a controller there would be more options. they are also a lot brighter when powered form a 12v source)
11997979_10154288302274896_421239620_n_z
11995432_10154288295614896_716322962_n_z
11994419_10154288295574896_682630046_n_z
11992614_10154288295624896_216252236_n_z
11992421_10154288295604896_347373291_n_z
11950809_10154288295589896_371032380_n_z
11880777_10154288295594896_1567394801_n_
https://www.sau.com.au/forums/topic/459493-r32-rgb-demon-eyes-mod/
What happens when you turn on the headlights?
headlights act as normal. the RGB stuff is on a separate circuit. can control from a switch or there are smartphone add on's to control it form an app.
if you have them on at the same time as the headlights the throw light normally but if viewed at an angle they a tinge of colour
Well I like messing around with the lights, but I think even with the red, green and blue all on making "white", it would still be a defect magnet as red and blue at the front of a car make the cops rather territorial about their colours.
Even many "white" leds tend to be towards the blue end of the spectrum (8000k or higher), and people have claimed to be defected or fined for that.
yeah they are on a completely separate circuit to the normal headlights or parkers. only really there for wank. track days or photos and such.
would be stupid to drive around with them strobe-ing different colours and hopefully the person i made them for won't do that
Edited by CRSKmD
  • Like 1
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
