I think I'm going to head in a different direction.
After reviewing more than my fair share of 34s, seeing lots of detailed pics etc, to be honest I simply cannot justify the asking price for what they are and how they present within my budget, as much as I love them. A truely mint one in my price range will be very mildly modified and should probably be left that way. Where as a mint and modified one is well outside my budget.
A few things have changed on my end also so I'll be shifting focus to finding a nice 33, preferably series 3, but anything with series 3 front end will be fine also (an I'll do that myself if I have to).
Keep me in mind if you come across any nice S3s - Pretty much Silver only as I've done the Midnight Purple thing - my god... never again.
Edited by ActionDan
32s are a bit old to me.
MNP is a whore bag to keep clean and it shows every imperfection.
I'm not fully ruling 34s out, will keep my eye out, but given a few things have changed on my end recently, I may pair back what I spend on a weekend/toy car and pocket that extra 20-30k I save for some other things.
I really should get my Silvia back to the track aswell...
Fair enough.
Having owned one 33R and 2 32Rs, given the choice, I'd have another 32R. Never had a 34 so can't comment.
My car is black, that is worse than MNP (surely). I just wash it every time I take it out... I'm on Perth end so let me know if I can help. I know the level of detail you'll be looking for..
I prefer the shape and interior and the fact that its physically smaller. its just old school cool.
Idk about 30+, there's loads to choose from in WA at least at much lower than that.
Dan, considered the N1 R33 GTR in Perth?
Yeah I agree, there's a few bunky 32Rs under 15 and a few good ones around 20. Couple built ones mid low 20s and your immaculate stock blah blah 30+ ones.
Its only on FB as is the way these days... I'll get you details.
Admin delete if not alowed
Rare gtr , genuine Vspec N1
One of only 16 in existance
Great investment for the future
Do not have a set price as of yet but need as close to $40, 000 as posible, she will only go up in value .worth every cent
Pm for serious enquirys
447hp , upgraded gearset, factory lmgt1's , top secret rear diffiser, front and sides from origin, engine is 24u .. for those that dont know thats nismos race spec motor, now running forged internals, hks triple plate clutch , top speed 320kph (no restriction on the mines ecu) , rev limit 10, 000 , oem carbon n1 spoiler , and heaps more
Seems the seller is not tech savvy. I read in comments mines ECU. I dare say he is clueless to actually knowing what he thinks he knows... I have a mutual with him (who has immaculate MNP 33R and knows his stuff). Maybe one to buy cheaper and fix up a bit to exactly what you want, knowing its got future value as its an N1?
11822961_936666409734619_910627712192864
Edited by 10 4
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
