OK for shits and giggles I enquired about this...
http://www.carsales.com.au/private/details/_/SSE-AD-3540905
Started talking to the guy on FB. Seems really friendly and helpful.
Assuming it would be a shitbox I started grilling him about how it's obviously been crashed etc.
He's tells me not in the time he's had the car (6yrs) and that he can't see signs of it having been hit... ok weird. "I tried to find the cleanest stock one I could".
Questioned the guards, bonnet, and front bar, boot.
He tells me, the bonnet came on the car, the guards he had made up (fibreglass but apparently really good quality, google tells me the nismo z tune guards are even fibre glass and only the actual z tune had CFRP guards).
The boot he had painted because he likes the look. Front bar and spoiler have been sold as he was not planning on selling the car. A top scret replica front diffuser is there as are the stock mirrors and guards.
He tells me the car also has a PFC (not listed on the ad), tuned for 240kw with stock turbos etc (1.2bar) as that's all he wanted.
Rims are also genuine.
I ask for some more interior photos - see gallery it's easily cleaner than the QLD car and not the existence of v-spec sensors on this apparently non v-spec car (i know you can add those sensors later indivudally and reconfigure the MFD or go the nismo MFD way)
He's getting me a VIN so I can do some digging and confirming K's etc.
He tells me underside is quite clean and nothing like the car i showed him and the only rust on the car is the two radiator tabs and that's why he showed me those.
I'm starting to think this could be a good cheap base to work off, spray the front bar, bonnet, boot, re-add spoiler (A mate of mine is an excellent spray painter with a business etc), get a rear diffuser and fit top secret replica front. -9s, injecotrs, pump, cams/gears and retune.
Am I crazy? OF course I would inspect for signs of crash damage, but if you could get this cheap and the k's and condition checked out...
http://imgur.com/a/FZIjK
Edited by ActionDan
Turbos seem to be about 1500-2k on the gtr group, injectors 500, fuel pump 200 or so and afms 4-500? 3k or so then a bit more if i wanted cams and gears, gears alone are bugger all.
Maybe 4k in parts there, rear diffuser is expensive 1500-1800 so i would just sit on that til i found one cheap.
The paint work would cost me the cost of the paint and some beers.
If you got the car for 40, spent 7 or so, that doesn't seem too bad?
The QLD car was going to be 46k with the spares so it would have come out cheaper but with all that rust to deal with and 55000 more ks (if the ACT car is genuine, wont surprise me if not).
Edited by ActionDan
8-10k if starting from scratch I think?
This has EBC, PFC and "full hks exhaust mines dump pipes" already.
I would be "guessing" to say that if it has dumps and an HKS exhaust it likely has fronts and cats done but fair point as that's extra cost, neither of which are that expensive.
Already has ATS clutch as per the ad,
Cam gears are cheap.
Tune is a valid point, I'm not sure if there's a 4wd dyno here so would likely get Chris at RacePace to tune it, when I spoke to him last he said tunes for adding mods like that aren't too bad, 4hrs etc, so less than 1k. I know some local tuners but the dyno access is the issue, one of the 4wd shops might have one but they get pissy about letting people use them.
I can do all the labour required (not painting but that's mates rates).
Edited by ActionDan
Dan that's a bit of a hidden gem imho.
Many won't have even considered because of the boot/bumper.
I personally would go stock guards, bumpers etc but that's me.
Leaves you a LOT of wiggle room to do things how you want. And you can play with cars again (aka hunt for parts etc)
DO IT
I thought that to switch R34 into RWD mod required bleeding the ATTESA system afterwards as it needs t be depressurized or something?
Didn't think it was as simple as dropping a fuse like the 32.
"I can do all the labour required".
I've fitted turbos before. Is it a shit job? Yes, but I'm capable of it. I've tuned (cheating as its only SAFC and SITC combo and some cam gears), aligned, and done all the upgrades on my track car plus all the service and repair of anything else I've had in the past including replacing a blown headgasket in the track car.
Swapping out a TT setup will be balls, but I'll get there when the time comes.
DO IT
I'm wondering this too. inspection and VIN review will tell me more so not getting my hopes up.
I like the Z tune guards, bonnet and bumper combo - once colour coded. Plus when I run off the track and smash up the front bar I won't cry as much knowing it was FRP.
I have the track car to play with so really I'm not looking to play with something else and don't get enough time as it is, but I'm not willing to drop 60-70 to get a fully done one how I want.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
