Something that did stand out about the car, I was just thinking about it, has an ATS twin plate carbon in it and when turning the car off there was a pronounced rattle as the flywheel/pressure plate stopped turning.
I'm aware of rattle on idle, but wasn't aware of pronounced rattle on shutdown.
Thoughts?
Slight rattle post ignition being off on mine as well (Nismo twinplate)
K's come back as 55000 at export in 2007, his records show 65000 on the odo when he bought it in 09/10 and it has 85 on it now, seems about right.
No auction papers due to when it was exported.
Jap history gave me that for free in the end given the delay, he mentioned email/hosting dramas.
I offered our services...
Looks like I'll aim for weekend after this one to go collect it and will start getting parts together and lining up the paint work.
Also...
Wanted:
VSpec front and rear diffusers.
Vspec pedal set.
Front inner wheel plastic sections - front most pieces left and right.
Rear spoiler, genuine or copy - but must be standard style. Carbon wing blade welcome.
Black wheel nuts - preferably Rays.
Rays Centre caps.
Nismo black drop sheet style seat covers front/rear.
Nismo gear knob, either the leather one or a black GT500 style one.
Things I will be selling/have to swap.
ARC Titanium Gearknob.
Bodyform Top Secret style FRP diffuser, with carbon look leading edge. Goes all the way back to the cross member. Pic below is of the same part, i can get full pics of the actual part when I collect it.
Rays red wheel nuts.
Standard mirrors in silver.
Standard guards in silver.
Freight to Wodonga will be required but I can also collect if anyone is in Canberra as I'll be up that way the weekend after this one. Collection from Melbourne also possible.
Cheers
Well I don't "have" it yet.
I'll be happy once it's aesthetically sorted. Power I'm in no rush for as it's just a street car and my days of racing everyone that might have looked at me are long gone.
  • Like 2
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
