Finally got specs on the short motor. No receipts for the parts but the pistons are stamped with spool logos.
The motor is prepped for a 26 head. the head stud holes are tapped out to fit oversized rb26 studs. New ARP head studs and cometic metal gasket to suit - an RB26 head will bolt straight on. ARP RB30 main studs have been used on the bottom end.
Main bearings are .25mm over
Big End bearings are .25mm over
Bore is 86.5mm – (0.5mm over)
compression ratio is 9:1
All bearings are ACL race bearings.
Have confirmed I'll go see him on Wednesday the 23rd, he has one other buyer from interstate trying to get up tpo see him and wouldn't accept a refundable holding deposit but said he would tell me if the other guy was going to get there before me - though he thought that unlikely.
I asked what sort of non refundable deposit he wanted if it came to that and he said just enough to cover doing another roadworthy if I didn't buy, couple hundred at most, so if the other guy gets there before me I'll just put that money down to give me a chance to inspect and first dibs on buying.
Car is in at Godzilla today.
I'm willing to risk a couple hundred to buy me time to get there.
He did say I was far and away the most engaged and knowledgeable buyer, the type of person he was hoping would buy (as the car is his baby etc).
He was fairly confident I would be inspecting first, but said he'd keep me posted.
I'm still trying to wrangle the inclusion of the PowerFC also as I have a mate who wants it :)
Some interesting/bad news.
Car went in for check over and tune - with the bigger exhaust on.
At 18psi, it only maid a bit over 300awkw, which seems low for -5s on 18psi. On 21psi, it made around 335awkw, which to me still seemed low based on RB26 dyno thread figures. Maybe those numbers are RWKW though? Anyone kow what the AW to RW loss is? I didn't think it was very much,
Also, compression test showed this.
150
155
160
135
165
155
That was a cold test. He is going to get it checked elsewhere cold and hot but 135 seems suspect to me, it's also greater than the 14 or so PSI the service manual allows.
I'm interested to see what a second test shows up.
Thoughts?
Spoke to Chris at Race Pace to pick his brain.
Got some pricing on rebuilds etc for reference.
Interestingly, he felt that the PFC was the better ECU for that car, but did admit the Haltech has a lot more features.
As per the above see what the second test shows up.
There's not enough $$ to come from spares to cover the cost of a rebuild at Race PAce, I do have some other options but just wanted to start with those guys.
He's just called me, gone and bought a new gauge and done his own test and claimed that cyl 4 came up as 160.
I questioned if that was warm or cold and he mentioned the car is likely still warm from being in the shop earlier and will do another test tomorrow morning dead cold.
That might explain why it's down on power.
I am so bummed right now I cannot even begin to explain it.
but they wont be able to handle the boost that the bigger -5's can.
I remember this topic being brought up once before, I think it came down to the volume of air that is being smashed into the motor is not much different between the 2. whereas with more boost the -5's leave -7s/-9's for dead
My 32 with -5's made 287kW rears on 18psi stock motor. So not interested in running more than 18 nor 300 club. I'd rather the non-blown engine club.
Seems pretty ok imo.
Made about 246 kW on 14psi as well, cant remember if I had changed anything from the 14 to the 18psi runs.
Edited by okooko
I've always thought you did both and should expect the same type of variance across all cylinders.
If one is down when cold then up when warm, that's a ring sealing issue - which could be rings or bores, but simply rules out valves.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
