Just curious if these are sought after wheels these days?
I have a pair of R32 GTR wheels and a set of 4 R32 GTS-T wheels, all powder coated the same colour.
They are currently on my S13.
Obviously the gtr wheels are on the back and a pair of the gts on the front.
I had them sand blasted and powder coated because gtr and gts wheels are a slightly different colour. I have all the center caps, which I've painted the same colour, and they look good.
I've had these for about 8-9 years and they're in great condition. No gutter rash and I think I've still got a can of touch up paint.
Im after a new look for my S13, something along the lines of some BBS LM's, and thought I would see if these are worth anything, to help fund some new rims.
I know a full set of the gtr wheels would probably be more useful, but there might be another S13 owner that wants a tough looking set of wheels, or a 32 gts owner who would like a pair of gtr rims for the rear.
I haven't got a price in mind, so I'm open to offers.
Edited by s13n1
Sorry, not an intentional bump here, just adding some additional info.
Front tyres are 205/50 Yokohama a533's with about 90+% tread.
The backs are just some cheap used tyres, they are a crappy size @ 215/60, but they are just over the wear indicators, so they're still roadworthy.
The photos were taken yesterday, all rims are even in colour, just some pics were taken in shade.
Second picture shows very small gutter scuff on the right edge. I didn't even notice it at first, just being honest here.
Although i've had these for about 8-9 years, the cars been off the road for most of that, which is why they're still in great condition.
Located Bendigo, Victoria.
$600
Edited by s13n1
  • 2 months later...
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
