it connects from the outlet side of the stock cooler to the throttle body / plenum
air pipe -> afm -> turbo charger -> piping -> cooler -> piping -> throttle body -> plenum
xxxxxxx -> xxx -> xxxxxxxxxxxx -> xxxxxxx -> xxxxxx -> pipe in red is here -> xxxxxxx -> xxxxxxx
https://www.sau.com.au/forums/topic/45954-please-help/#findComment-934826
Are you referring to the pipe that has the "Air Inlet" or "Vacuum hose"?
I thought you mean the larger "Air Inlet" hose
If Air Inlet: it goes the throttle body / inlet plenum
If Vacuum Host: it looks like it goes the boost controller, will get a pic of mine tongiht from rb25det
https://www.sau.com.au/forums/topic/45954-please-help/#findComment-935402
no problems. on my rb25det there is a small tube running to the intercooler piping which goes to the throttle body. the small tube you are talking about goes the the factory boost solenoid. Im not sure how and why its such a small tube and yet it manages to control boost to 7psi (lacking knowledge of air pressure stuff) but thats where it goes
will try nad get a pic tonight or tomorrow
https://www.sau.com.au/forums/topic/45954-please-help/#findComment-935588
are you using a boost controller?
if not, you put a 6mm hose from that nipple directly to the wastegate. if you are using a BC its a little more complicated. and yes, you must have a pressure signal for the wastegate so you'll need to put one in your pipe. hybrid kit i bet isn't it?
-rb25
https://www.sau.com.au/forums/topic/45954-please-help/#findComment-935627
