R34 GTT 5sp manual Skyline RB25neo/30. 400 RWKW.
RELUCTANT SALE OF MY PRIDE & JOY DUE to arrival of second Child.
Rebuilt motor @ 116250km
BLOCK - bored, honed, decked, crand plugged & balanced, crank collar, N1 oil pump with 2JZ style billet gears, ARP headstuds & series 2000 fasteners. Rebuilt motor at 116,250 km.
375KW @ 18 psi
400KW @ 22 psi
HEAD - CNC ported & polished, performance valve springs, GREDDY plenum, tomei 260 degrees pon cams, super spark coil packs, 650 cc injectors, multi layer metal gasket. 6 boost exhaust manifold with borgwarner s366 turbo. haltech platinum pro ecu.
4" to 3 1/2 dump pipe, 3" cat back stainless exhaust with Magnaflow cannon. 600 x 300 x 100 intercooler with 3" stainless piping. 6 puck ceramic Jim Berry race clutch. BC BR type adjustable coil overs. KOYA 18 x 8.5 fronts with 225 tyres. 18 x 9.5 rears with 265 federal tyres.
Dual walbro fuel pumps in tank. Tuned on 98 Octane, 400 RWKW @ 22 psi.
Spool Forged Conrods
Blitz Electronic boost control
Front Strut brace
Front tie rods
Rear camber rods
Rear traction arms
Major Service just completed by Mercury Motorsport including
Dyno Tune and
(heater core replacement $2000 alone) full service just under $5000 has always been very well cared for, always garaged. definitely worth a look!! Feel free to call if you have any other questions.
Jarrod
0407992457
Car Located Brisbane South
Edited by JSC213
https://www.sau.com.au/forums/topic/459540-r34-gtt-for-sale/
Hey mate your photos are not showing up here. Found the car on Carsales: http://www.carsales.com.au/private/details/Nissan-Skyline-1998/SSE-AD-3585295/
Very nice, GLWS
  • Like 1
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
